Old June 9th, 2019, 21:56
randy57 randy57 is offline
1990 Renix Coolant Temp Sensor Question
Has anyone recently replaced their coolant temperature sensor in their 1990 4.0? This one is the stock one and fits into the side of the block up by the left engine mount? If so was it like this one or did you have to modify an aftermarket one?
Thanks in advance.
Old June 10th, 2019, 05:31
tjmotter's Avatar
tjmotter tjmotter is offline
Re: 1990 Renix Coolant Temp Sensor Question
Thanks in advance.
hmm.. the coolant sensor on my '90XJ is located on the back of the head on the drivers side. Are you sure that isn't the knock sensor?
Old June 10th, 2019, 05:55
cruiser54's Avatar
cruiser54 cruiser54 is offline
Okay.
Temp SENDER for the gauge is at the driver's side back of head.
Temp SENSOR for the ECU is down low on driver's side block.
Temp SWITCH for turning the electric fan on is in the lower left hand side of the radiator.
Now, to the OP: Why are you wanting to replace that SENSOR?
Old June 10th, 2019, 11:52
Originally Posted by cruiser54 View Post
Okay.
I was referring to the sensor that is down low on driver's side block, like you had mentioned, just behind the motor mount bracket. It's 1/2 inch or so above the oil pan.
I thought it was a coolant temp sensor. I think it was moved to the thermostat on later years.
I wanted to upload a picture of it but the only option I see for that is via a webpage link
Old June 10th, 2019, 12:05
The sensor in question is the knock sensor. Thought it was the coolant sensor. My apologies to everyone.
Old June 10th, 2019, 12:09
Yes it is the knock sensor. My apologies for the confusion.
Old June 10th, 2019, 13:58
cruiser54's Avatar
As soon as I saw "1/2" above the oil pan" I was suspicious. LOL. It has a connector identical to your fuel injectors.
Old June 10th, 2019, 14:06
It does.
I was freaking out because I did a ohms test on it and got nothing.
Called dealer for a part number I could reference. But all the coolant temp sensors I searched for and part number I got looked nothing like the knock sensor (which I thought was the coolant sensor)
I was thinking: here I go again, scrap the jeep because of a small part I cant find.
Old June 10th, 2019, 14:16
cruiser54's Avatar
It does.
well, you dodged a bullet!!!!
Old June 11th, 2019, 07:32
Saudade's Avatar
Saudade Saudade is offline
The new sensors are different in that they are 2 piece. Basically a stud that screws into the block, and the sensor that sips over the stud.
The one on my '88 hasn't worked in years.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old June 11th, 2019, 22:14
Yea, that is the one that goes to your gage.
The other one in the side of the block goes to the ECU.
Coolant temp sensor renix idle problems? Precious88xj OEM Tech Discussion 14 May 2nd, 2018 12:39
88 XJ Renix Coolant Temp Sensor Rplmnt ptf18 OEM Tech Discussion 5 February 27th, 2016 16:10
Coolant Temp sensor for RENIX, location after swapping to HO. stockli OEM Tech Discussion 7 April 3rd, 2010 21:07
Renix Coolant Temp Sensor question.. stephenspann27 OEM Tech Discussion 18 January 13th, 2010 07:34
Coolant Temp Sensor causes High Idle RENIX? Storydude OEM Tech Discussion 3 June 8th, 2005 18:34
