Old June 2nd, 2019, 22:35
Weasel's Avatar
Weasel Weasel is offline
Auxiliary Electric Fan
Had my fan in the 00 blow out a few chunks of the blade the other day. Looking on rockAuto there are several different versions and prices points. Are the cheaper ones good quality or do you just stick with the mopar fan?
TYC: $44
GPD: $47
APDI/PRO: $54
Four Seasons: $59
Spectra: $78
Mopar $290-334
Just add lightness
Old June 3rd, 2019, 01:07
Ralph77 Ralph77 is offline
Re: Auxiliary Electric Fan
I just bought this one for my '00.
https://www.ebay.com/itm/Radiator-Co...72.m2749.l2649
I did my water pump and one of the tabs is busted on my fan. Has been since the day I bought the Jeep. Been gluing it, and it really does not hold, but it really was fine. Problem is it just annoys me.
Couple things I found out. It does not look like a factory fan as shown in the picture. That kind of bothered me. Cause a dumb idea I had was using my fan in that housing. Looks like mine still might swap in there anyway. Might give it a go at some point.
Also the pigtail off the fan was long. At first I was WTF on that too. Know how they use one of those plastic tabs attached to the connector to secure it in a hole. Well I found a hole farther away down by the headlight to secure it to. Turns out this might be better cause I have more wire to move the fan out of the way without disconnecting it. I try not to play with connectors when ever possible. 20 year old brittle plastic and all.
Also the tabs at the bottom have these ridges. Starting narrower at the bottom and getting bigger as they go up. They secure the fan in the slots nicely and think cause those metal clips like on the factory ones are not used there is less of a chance to bust a tab if you do remove it. That is what might have happened to mine. First thing I did to the Jeep was replace the radiator all those year ago. Not aware of the metal clips and yanked it out. Had I know about the clips would have gotten under there with some pliers and gave them a squeeze before pulling up on it.
It seems to work as it should. Does come with a lifetime warranty. Which really does you no good if you have to replace it every other week but again so far so good.
To see some shots, I don't use a 3rd party thing so can't post any here, read Post #90959.
https://www.cherokeeforum.com/f59/wh...940/index6064/
Old June 3rd, 2019, 07:38
Heavyopp Heavyopp is offline
I've used the TYC version on 2 different cherokees -- Fit fine, work fine -- one has been in for over a year the other was very recent with little miles
Old June 3rd, 2019, 08:03
Black1990jeep Black1990jeep is offline
I bought a mail order fan, sent it back, the brand I dont recall. The blade to shroud gap was huge compared to stock, thus a loss in efficiency. The electrical connector although it looked right, was too big to fit the other end on the chassis.
I thought Id swap my old shroud to the new fan, but they were not compatible, so back it went. chinese junk!
I sourced a good used fan from the wrecker. Nice original type, but off a later cherokee so I got fancy curved fan blades.
Old June 3rd, 2019, 16:35
Weasel's Avatar
I'll give the TYC a shot. Not much for junkyard stuff around here.
Just add lightness
Old June 3rd, 2019, 17:27
RCP Phx RCP Phx is offline
Last year I bought a VDO and was very impressed with it. I thought I got it from RA but I don't see it listed.
Old June 3rd, 2019, 19:06
jbeintherockies's Avatar
jbeintherockies jbeintherockies is offline
I very recently installed the TYC 620560 Jeep Cherokee Replacement electric fan. It is currently $39.35 on Amazon.
No complaints yet. It is a very quiet fan.
Old June 3rd, 2019, 21:31
Weasel's Avatar
That's where I got mine, prime shipped. RockAuto was $10 for 10 day shipping.
Just add lightness
Old June 10th, 2019, 15:05
Weasel's Avatar
TYC is in and seems fine. The Factory fan has about 60% glass fiber in the plastic. The TYC has some Glass Fiber but no stamping to tell exactly how much.
Just add lightness
Old June 11th, 2019, 20:28
puredrive puredrive is offline
I just ordered from Amazon TYC. Quiet compared to the factory.
97-01 XJ Auxiliary Fan upgrade. streetxj Jeep Street and Performance 16 September 29th, 2013 19:23
Auxiliary electric fan blade JeffU Wanted: Private Party Only 2 November 9th, 2006 06:29
anyone know cfm of stock auxiliary fan? 93xj-jeeper OEM Tech Discussion 5 August 28th, 2005 15:00
Auxiliary fan not running bustednutz OEM Tech Discussion 12 June 21st, 2005 16:33
Auxiliary Fan Bronco OEM Tech Discussion 17 April 28th, 2004 23:50
