purvisdotcom
- Hawaii
My 89 MJ project. It starts up fine, can even drive it(although the clutch is whining at me with the pedal engaged, even in nuetral) but everytime after about 5-10 minutes the engine stalls out and won't restart at all. then after it cools down(maybe a half hour or more)it will start up again and do the same thing.
One thing I notice is that the fuel pump does not make any noise when I turn the key forward when the engine is hot. Is there one of the sensors that would cause this or is it just a bad pump maybe. I read in one post that when the pump starts going bad, it can shut off when hot. I guess I never really thought that the pump got very hot in the first place.
Maybe I should check the electrical signal to the pump when the car isn't starting?
Oh yeah, also my idiot light for temp is always on when the key is in, I wonder if the temp sender is bad and if so would cause this?
