Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period. |
Thread Tools | Rate Thread | Display Modes |
hey, im thinkin its about time to make list of all the lingo we use here. it would be cool to make it a sticky too... so this is what i have figured out:
IIRC - If I Remember Correctly SPOBI- Stop Putting Out Bogus Information HTH - Hope This Helps IMO - In My Opinion IMHO - In My Humble Opinion CE - Check Engine TC - Transfer Case TPS - Throttle Position Sensor NSS - Neutral Safety Switch CPS - Camshaft Position Sensor TIA - Thanks In Advance BTW - By The Way ROTFL- Rolling On The Floor Laughing NHV - Noise, Vibration, and Harshness BPE - Bar Pin Eliminator LCA - Lower Control Arm UCA - Upper Control Arm CV/dshaft - Not a true Constant Velocity as it would seem, but actualy a near constant velocity, double-cardan-style universal joint shaft, commonly refered to as a CV joint. there are no true Constant Velocity shafts on Cherokee's unless someone has gone way outside of themselves and made something to use one. TSB - Technical Service Buliten FSM - Factory Service Manuel HO - High Output VSS - Vehicle Speed Sensor IAC - Idle Air Control - also refers to Idle Control Vavle OBD-II - On Board Diagonostics (Type 2) ODB-I - On Board Diagonostics (type 1) welp thats all i got, feel free to comment and add more... just trying to help others out... |
#2
Re: Abbreviations
![]() NAC- North Atlantic Chapter MWC- Mid West Chapter SEC- South East Chapter blah blah blah SOP- Standard Operating Procedure YMMV- Your Mileage May Vary WRT- With Respect To LH- Left Hand RH- Right Hand IB- Inboard OB- Outboard OTOH- On The Other Hand DS- Drive Shaft STFU- Shut the Funk Up |
#3
Re: Abbreviations
Once again, it's important not to extrapolate from your year and model to assume that the same specs apply to all years. Some of the very early Cherokees (and XJ Wagoneers) did use true constant velocity joints in the front drive shafts and front axles. Commonly referred to as the "beer can on a popsicle stick" drive shafts. This is the primary reason I wish people would refer to the double cardan drive shafts as "double cardan" drive shafts rather than as "CV" drive shafts -- to avoid confusion, since Jeep did use both and often the questions are asked without stating what year and model is being asked about.
Eagle - Lifetime ![]() Owner/Driver/Enabler of "The Fleet" Self-appointed President-for-Life of the World MJ Preservation Society |
#4
Re: Abbreviations
SNAFU-
Situation normal all Funked up..well not funked..but you get it ![]() |
#5
Re: Abbreviations
FUBAR- Funked Up Beyond All Recognition
#6
Re: Abbreviations
Tts.
#7
Re: Abbreviations
Re: Abbreviations
thanks |
#9
Re: Abbreviations
Dont forget BOHICA- Bend Over, Here It Comes Again.
CSV- Chronic sedimentary vaginosis...sand in the vag. Fergie |
#10
Re: Abbreviations
Re: Abbreviations
![]() CYA- Cover Your Ass... like the TV stations did who were supposed to play the movie. |
#12
Re: Abbreviations
btt - back to top
ttt - to the top DS - drive-shaft WMS - wheel mounting surface DOM - drawn over mandrel (tubing) ERW - electric resistance welded? (tubing) hp - horsepower (duh) Al - Aluminum .... |
#13
Re: Abbreviations
Re: Abbreviations
oh, and of course the Jeep designations:
XJ - Cherokee, duh 1984-2001 MJ - Comanche 1986-1992 YJ - leaf sprung Wrangler 1987-1995 TJ - coil sprung Wrangler 1997-present ZJ - Grand Cherokee 1993-(1998?) WJ - Grand Cherokee (1999?)-2004 WK - Grand Cherokee (IFS) 2005 KJ - Liberty 2002-present |
#15
Re: Abbreviations
Are those really abbreviations though?
Don't forget CJ, DJ, FSJ. |
Thread Tools | |
Display Modes | Rate This Thread |
Post abbreviations.... | Loose_Nuts_Enterprises | Non-Tech / Off Topic | 10 | December 27th, 2003 03:46 |
