Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
  #8431
Old July 13th, 2019, 11:36
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Re: What was done to YOUR rig(XJ/MJ) today MECHANICALY????
did you see the 6.4L hemi swapped 2020 Gladiator that Dennis Collins did at their shop? Insane! he did a donut in it with 39" BFGs.
Old July 13th, 2019, 16:20
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Originally Posted by IslanderOffRoad View Post
Not XJ related but my lease on my daily is up soon. Test drive a Gladiator and a JL Wrangler yesterday. May be an all Jeep household soon
Super nice looking, 87 Wagoneer, D-44 rear Ltd Ed, 4x4 with all the bells and whistles for distressed sale up north, NY area I think?
https://www.facebook.com/groups/7732...eply&ref=notif
Last registered in 1992, used as a snow blow till last year. Jeep guy that bought wants to give up over the title issue. Ready to sell it or parts.
Its a Wagoneer group on Facebook.
Pass the word, that rig needs to be saved, It is almost exactly like mine, except the wood trim out side.
Salvage title is not that hard in Texas IIRC, or use a mechanics lean or??? Or collectors title?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old July 19th, 2019, 19:49
DeftwillP's Avatar
DeftwillP DeftwillP is offline
Went outside to change the oil and realized I still donít own an Xj anymore.
Old July 20th, 2019, 04:56
xjintx xjintx is offline
Me neither Will... and don't actually miss it. Had XJs for many years and loved them... but guess I'm done.
Old July 20th, 2019, 09:49
Ecomike's Avatar
NAXJA# 2091
Oh wait, that means more XJ's for me? :-)
LOL
I have a solution to your all's problem. Shop on Craigs list and Facebook.
Plenty out there looking to be adopted by a new family.
We still have 6 XJ's and one Liberty in the family.
One will never be driveable again (rolled on the freeway), but its still hear at home, ready to donate parts to the others.
Originally Posted by DeftwillP View Post
Went outside to change the oil and realized I still don’t own an Xj anymore.
Old July 21st, 2019, 11:38
HokieAirman HokieAirman is offline
New engine refresh. Painted and installed oil pan, installed new rear main seal, replaced oil pump, replaced water pump, replaced thermostat.
Sent from my SM-N950U using Tapatalk
Old July 22nd, 2019, 18:44
denverd1's Avatar
denverd1 denverd1 is offline
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old August 15th, 2019, 11:10
devildog0's Avatar
devildog0 devildog0 is offline
Dropped in a replacement 97+ fan to replace my original efan from my 95 that had a busted frame. Replaced my pin style wiper arms with some 97+ wiper arms plus new wipers, then did a very slight adjustment on my driver's door striker pin to get the rear of the door to seal properly.
https://www.youtube.com/watch?v=f1yhTr3JEWA
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old August 16th, 2019, 10:53
R6TeXJ's Avatar
Finally got my 120amp alternator installed. Clearanced the brackets and the timing cover for the larger alternator to fit.
As I was putting it back together for the last time, the upper bolt on the aluminum bracket, went loose...oof I think the threads gave out on the block.
I just left it there. Need to keep an eye on it to make sure the bolt doesn't back out.
For now, there are plenty of bolts holding the alternator in.
Old August 23rd, 2019, 17:30
devildog0's Avatar
Replaced my swaybar link nuts with wingnuts for cheap discos.
Sent from my SM-G892A using Tapatalk
Old August 24th, 2019, 02:00
Ralph77 Ralph77 is offline
Little blue threadlocker maybe?
Old September 28th, 2019, 16:19
devildog0's Avatar
Busted some.tires off the 2 SE wheels I've managed to acquire after installing some drop anchors in my garage for my cheap ass tire changer.
Now to prep the wheels and paint them then scrounge up 2 more.
Old October 17th, 2019, 18:08
blamp28 blamp28 is offline
Heater core and halfway into right front wheel bearing and U-joint
Old November 13th, 2019, 20:26
devildog0's Avatar
Found the idler pulley squeaking when cold.* Also has some.wobble to it.* Ordered a new one
Was getting a gas smell and found a very small leak at the fuel pressure regulator. pulled it out and the original 25 year old orings finally gave up the ghost.* Im guessing our recent spat of cold weather finally did them in. Found an oring in my parts pile to replace the outer o ring which stopped the leak but didnt have the inner oring so my fuel system wont hold pressure when the engine is off. Ordered a new Delphi branded unit*
Changed oil 300 miles early cause i had the time.* Rotella T4 10w30 and a mopar filter.*
Old November 24th, 2019, 18:54
devildog0's Avatar
On the Jeep
Put a new spherical bearing and spring in the front drive shaft.
Put a new PL259 connector on my radio's coax
Installed caster adjustment shims on the lower control arms in an attempt to track down my front driveline vibes
Rate This Thread:
What was done to your rig today? A7XJ Arizona Chapter 1781 March 26th, 2016 21:13
In serious need of some help today. DrMoab Intermountain Chapter 16 November 30th, 2010 20:52
Tried out the TSL's today TheInstaller Jeep Picture Showcase 12 May 7th, 2007 22:16
new 37's came today!!! atowley Modified Tech Discussion 17 February 23rd, 2004 09:02
