Old January 22nd, 2018, 22:24
PhotoJared's Avatar
PhotoJared PhotoJared is online now
Re: Projext "V8 XJ" Build
Originally Posted by ehall View Post
Great pic
Previous owners picture. I think it was out in Moab.
I havenít taken delivery of it yet. Heís a super nice guy and is doing some maintenance work heís been putting off (wheel bearings and an ARB locker leak)
Old February 4th, 2018, 17:58
PhotoJared's Avatar
New XJ is in my possession!
The stable:
Old February 4th, 2018, 18:03
PhotoJared's Avatar
Currie Ford 9" front with D30/44 Reid racing outers
PSC hydro assist
Synergy 3 link
Currie Antirock
Bilstein remote res shocks
Deaver springs
The stable:
Old February 4th, 2018, 18:04
PhotoJared's Avatar
OMG I hate that I cant edit a post on this forum
racer32's Avatar
racer32 racer32 is offline
Looks nice �� although that rear shackle angle is a bit suspect
Old February 4th, 2018, 18:37
cleenrob's Avatar
cleenrob cleenrob is offline
neat
thats quite the front axle
Old February 4th, 2018, 18:41
PhotoJared's Avatar
Yea there are some items that I need to fix. I'm probably going to move to the Boostwerks shackle.
Its a small list of things that need fixed.
Re-Bleed PSC steering
Fix Exhaust leak (I think Its coming from the header area)
Alignment
The cut and fold was done a bit sketchy so I'm probably going re-do it or get some metal inserts
Old February 5th, 2018, 13:04
PhotoJared's Avatar
Originally Posted by cleenrob View Post
neat
yea its definitely different lol
Old February 11th, 2018, 01:34
PhotoJared's Avatar
So I was doing some measuring this evening....I donít think the LS will fit in my new Jeep. The ford 9Ē pumpkin is more centered on the axle than the front d30 in the red Jeep. The driveshaft is shifted nearly 1.5Ē to the passenger.
This would take away any space between the driveshaft and the oil pan/oil filter. I donít know where I would run the exhaust let alone have enough room to flex the suspension.
Iíll post a couple of pictures tomorrow
Old February 11th, 2018, 11:58
PhotoJared's Avatar
OK pictures...
This is the red jeep. Stock D30 front axle. All measurements were taken from the middle of the LCA mount. The D30 driveshaft is about 8-9" from that point. The pumpkin is about 12-13" overall.
Here is the F9". Notice the driveshaft is about 10.5-11" on the same measurement. The third member is at about 15". That takes about 3" of clearance between the pumpkin and the oil pan area. Not sure...
Old February 11th, 2018, 12:01
PhotoJared's Avatar
sorry for the gigantic pictures guys...
First one:
Second:
Old February 13th, 2018, 16:33
clydefrog's Avatar
clydefrog clydefrog is offline
You mean your new ford 9" wont fit the LS : )
What about a D44 or swapping over your D30 and beefing it up?
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old February 13th, 2018, 18:58
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Ok. c'mon now. I'm probably one of the bigger supporters of the Dana 30 out there, but there is no way I'd keep a Dana 30 under a rig with a V8 swap and anything other than stock sized tires. Especially not an LS.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 13th, 2018, 21:48
clydefrog's Avatar
I have. And mine is a modified LS. The D30 can be pretty strong, I'm not running a locker, just a trutrac, but I'm not easy on it either.
Old February 14th, 2018, 00:15
indian's Avatar
indian indian is offline
I have also an LS with stock Dana 30 (except gears and aussie locker) and it holds good yet. I think with moderate foot on gas pedal should be no problem.. we will see :-)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 294 April 27th, 2018 18:42
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 22:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 03:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 02:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 12:19
