All,
I know fixing oil leaks on a jeep is sort of a futile effort, but I'm making an attempt at it.
99' XJ 4.0 AW4 NP 231. 185K miles now, stock except for after market tube front bumper.
Took a bunch of work to get the oil pan off but succeeded last night. This morning, got the rear main cap off and removed the rear main seal from the block and cap it was pretty toasted. Also replacing the oil pump for good measure, I'm in there might as well. Ordered a Melling HV pump to help combat aging bearings.
Also this morning, removed the harmonic balancer and attempted to remove the front seal from the timing cover with a regular seal puller. I also have the front bumper off to aid in access to the front of the engine. I can't get a good angle on it to remove the seal. It doesn't look like there is room to get a 2-3 jaw puller in there.
What has everyone else done to get the seal out of the cover? Do you need to remove the timing cover to get the right tools involved?
Any advise appreciated!
Also to be done this coming week:
Oil pan gasket (Obviously)
Oil Pump
Rear Main
Front Main
Valve Cover Gasket
Valve Cover Elbows
Ignition Tune Up
Thanks for reading appreciate the help.
Oil Pump
Rear Main
Front Main
Valve Cover Gasket
Valve Cover Elbows
Ignition Tune Up
