Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 84 votes, 5.00 average. Display Modes
  #16486
Old July 2nd, 2018, 08:50
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Re: Weekend is over...what did you get done?
I've been working with Glenn on his MJ every chance I got and he got. We got stopped dead yesterday when we realized we ordered the wrong front brakes.... Crawl 2019!
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old July 2nd, 2018, 09:47
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Originally Posted by PacificEd View Post
I went to Ivy Bluff and scored some goodies for the Grand. Found a nice set of seats with manual bases, a couple transmission dip sticks and an OEM transmission cooler.
It was so hot on Saturday and the seats fought being removed. A captured bolt on each base broke loose. But we did get them out.
Where is Ivy Bluff?
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old July 2nd, 2018, 12:07
PacificEd's Avatar
PacificEd PacificEd is offline
Regular Joe
The address is listed as Morrison, TN. It's not too far from my house.
The only bad part about this yard is the cars are just set on coarse gravel. It can be a challenge to walk on if you have bad knees. Also, it makes it tough to get anything off the underside of the vehicle. They will come out and prop them up for you to get underneath though.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old July 5th, 2018, 16:35
PacificEd's Avatar
Regular Joe
My front passenger side brake caliper stuck a few weeks ago. I rounded up some new pads and rotors and picked up new calipers and brake lines. In my experience with Chryco products, most often the lines fatigue and cause the problems.
I used this SP3 penetrating oil to soak the brake line connections. Broke free nice and easy using a flare wrench.
I got everything done and bled the brakes. Everything worked great. Now my 1994 is back in service.
Old July 12th, 2018, 13:24
bosco01xj's Avatar
bosco01xj bosco01xj is offline
NAXJA Forum Addict
OK... so i could buy 37s with wheels for $500. I just need rollers anyway to get this thing out of my garage. I'm no where near ready for 37s axle wise. I think I may go ahead and buy them.
Old July 12th, 2018, 14:17
PacificEd's Avatar
Regular Joe
How much lift do you have?
Old July 12th, 2018, 14:23
Ghost's Avatar
Member Number 257
I am on my second set or rotors for the mj. the first set was the late model. My mistake. This set is supposed to be for the early brakes. They will not fit over the unit bearing...... WTH!!???
Old July 13th, 2018, 07:25
bosco01xj's Avatar
NAXJA Forum Addict
Probably around 5.75 inches.
Old July 22nd, 2018, 18:31
deesiexj's Avatar
deesiexj deesiexj is offline
Installed my new AFE intake. I got the Momentum ST intake, and I'm pretty impressed. Definitely noticed a bit more power on the highway. Nothing crazy, but I'm able to hold 4th gear at speed on inclines without hunting for gears like usual. Also picked up ~2 mpg over the exact same drive I did a week ago. No idea if it meets the power claims they make, but I'm happy with the improvements I marked
Old August 1st, 2018, 09:44
PacificEd's Avatar
Regular Joe
I put some new Skyjacker H7016 shocks on the front of my 1994 XJ and it sure rides a lot better. I'd like to have gone with Bilsteins but so far I'm happy and saved quite a bit.
I also was able to swap in the front seats I bought at the junkyard a while back. I took out the power seats from the 98 ZJ and swapped in manual bases and decent seats. The wife is a lot happier.
Old August 2nd, 2018, 07:44
bosco01xj's Avatar
NAXJA Forum Addict
We are moving at the end of the month within the same city. This kind of happened suddenly and has certainly provided me with a sense of urgency to get my Jeep movable. it's been on jack stands for months. I finished up the front yesterday.
I had a great time with the pitman arm and had to end up cutting it. I broke the rented pitman puller and used the TRE puller to pop it off.
I bought tires and wheels earlier than expected because with the KJ disc conversion on the rear, the 15 stockers don't fit.
I've got 285/75/R16s that are scheduled for delivery today. All that's left to get this thing drive-able to the new house is mounting and installing tires and bleeding brakes.
Here's a list of must-dos before I take this rig wheeling:
1. Flush cooling system-It's nasty.
2. Adjust transfer case shift linkage - keeps popping out of 4wd
3. Replace U joints on front axle.
4. Maybe install an SYE. Not sure yet.
Old August 2nd, 2018, 08:07
Ghost's Avatar
Member Number 257
We've got the Mj on all 4 again. Hopefully going to button it up and have it driveable in a couple weeks. Assuming all goes better then this whole build has gone.
Old August 3rd, 2018, 14:46
043500 043500 is offline
Replaced all the bolts on the MJ's steering linkages and was able to remove the broken bolt from the pass side leaf perch on the front axle.
Drove it to work today just because I could.
Hoping to pull the engine/trans/t-case from the 99 donor this weekend and pull that motor off (it's bad). Then over the next couple weeks get the good motor out of the 4 dr MJ and then stab the good motor and trans/t-case into Cal's jeep. He'll be 16 at the end of November so we gotta get it on the road soon.
1987 MJ renix 4.0/AW4, D300, 60/14B welded 5.13's and 37's.
1993 XJ 2 dr, 5" lift and 32's
2003 dodge ram 3500 cummins
Old August 6th, 2018, 08:40
Got the bad motor and then trans/t-case out of the 99 to get ready to go in Cal's '93.
Almost afraid the t-case is bad but we'll see.
Hoping to pull the good motor out of the 4 dr MJ Friday eve then get ready to stab it all in the '93. Have Jeeptoberfest mid October...hoping to be ready by October 1 to do shakedown driving beforehand.
Holy crap his 16th birthday is coming up quick!
Old August 6th, 2018, 21:24
bosco01xj's Avatar
NAXJA Forum Addict
So, my tires never shipped. Apparently the casings were failing and Treadwright never told me of the delay/ backorder. I asked them to refund me and I just bought BFGs same size for only $80 more total brand new from 4 Wheel Parts. I know a lot of guys run Treadwrights but unfortunately I canít recommend them. Iím disappointed in their customer service.
Rate This Thread:
What I did this weekend Starscream Modified Tech Discussion 27 January 6th, 2008 22:28
Took the weekend off.... jpbxj79 Colorado Chapter 3 July 24th, 2007 22:15
2nd Annual NAC Mohawk Madness Weekend Sept 3-5th labor day weekend sidriptide North Atlantic Chapter 77 September 19th, 2005 20:48
anybody going anywhere this weekend? MMIXJ Colorado Chapter 5 September 10th, 2004 15:19
