Parting out two 2002 Liberty KJ's in SE WI
Status
Not open for further replies.
jeepcomj
wisconsin
Hi,
I'm currently building one liberty out of two, and found another one to tag along for the ride.
I basically have two complete libertys worth of parts. Both 2002.
Parts I have;
transmission 130k miles $300
transmission 100k miles $350
transfercase (np231) 130k miles $200
transfercase (np231) 100k miles $250
front differential 3.73 ratio 130k miles $300
front differential 3.55 ratio 100k miles $250
steering gear (rack and pinion) complete with t.r.e. 130k but newer ends $125
steering gear (rack and pinion) complete with t.r.e. 100k but newer ends $175
Both Rears are complete drum to drum with good brakes, brake hoses, lines. nothing was cut, includes bolts.
rear axle 3.73 130k miles $350
rear axle 3.55 100k miles but has been fully rebuilt, new bearings, gears, etc. $450
Driveshafts front and rear x2
130k front $50
100k front $75
130k rear $50
100k rear $75
two interiors.
charcoal and light grey.
two sets of charcoal seats, less wrecked driver's side on one of them.
no light grey seats. Everything is in good condition.
one headliner was dyed black, but looks good. both headliners nice, no sunroof, no EVIC
two carpets. charcoal is nice, light grey needs cleaned but isn't terrible.
two steering columns, complete, good to go with good airbags, cruise switches, radio controls, etc. $170 each
All exterior body panels are Cactus Green
two rear liftgate doors. both cactus green, both nice. one is missing tire carrier, but complete with wiper and arm in good shape. both come with hinges and retainers. $150 each
rear liftgate glass x2. heated. good shape, come with hinges and struts, $75 each
two driver door glass, good shape, factory tint on rear. $50 each
also have door guts, but regulators are bent
two complete passenger doors, front has mirror (non-defrost). don't want to strip if I can avoid it. $150 complete door less flare on rear
one pair of decent shape rear doors. light dents on door handle area that will pull out with little effort. $100 each, complete
passenger front window glass, non-tint. $50
also have door guts, everything in good shape. door skin unfixable
x2 factory roof rails. pay shipping or come pick them up.
one good windshield. $40 you pull
one good complete front clip. light damage behind flare on driver's side near the rocker. very easy to fix. minor scuffs here and there, but all around nice shape with no dents aside from on the driver fender
i have
front bumper with fogs and turn signals
grille $50
driver fender without flare, with plastic inner fender $100
passenger fender without flare, with antenna and plastic inner fender $100
hood $100
headlight/core support with lights $100
rear passenger quarter panel with glass, nice shape, cut from vehicle $150
Rear quarter glass x4 two of each side, factory tint, good shape $45 each
two passenger rocker panels, one driver $50 each no rust no dents
front inner fender supports for if you've got a front end collision and need to repair $75 each. two good driver's side, one good passenger
front bumper support $75 complete all the way across
complete wiring harness x2 make offer on what you need
front a-arms, struts, knuckles, calipers. all stock, all in good shape with good joints make offer, have two sets
front diff axle cv shafts x2 both sides. $75 each get some trail spares
non-skid trans x-member mount $50
Renegade skid package. includes;
k-member skid
tcase skid and crossmember
gas tank skid
$200 takes all or will divide
Renegade fender flares. cactus green, nice shape, couple of light scuffs. complete set $120
x2 gas tanks. one has a newer fuel pump, one is OEM. $100 each, both work great
have other things like BCM's, gauge clusters (black surround trim), keyless entry remotes, sensors, wiper arms and motors etc. make offers
I do not have any good light bars.
I'm sure there are parts I've forgotten, so let me know what you need.
Thanks,
Pat
I do also have one good 3.7l motor with low (unknown) miles on it as it was replaced in one of these vehicles. I will sell it for $1200, or keep it and buy one to put it in. You can hear it run.
I did, and put that light bar on the one I'm building. Actually bought the Tboned one solely because I needed the lightbar.
forgot to add, one set of the color matched renegade alloys, and one set of regular liberty alloys. 16s, two different sets of 5, good tires (70% or better) on both sets.
renegade ones $475
liberty alloys $350 one has curb check but works
i'll buy the cactus green rear passenger fender flare for my renegade... a tire with cactus green rim and windshield wipers. please provide quote :)
thanks,
sara
No more liberty parts
Status
