Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old March 22nd, 2005, 21:52
Gridlin Gridlin is offline
On a Time Out
Extended Idle???
I have a 94 XJ 4.0 4x4, it used to be a Sheriffs K-9 vehicle. I know the extended idle button just to the left of the steering wheel is there because law enforcement usual sit at idle for long periods. Besides turning on the AC, fan and bumping up the idle, just curious does anyone know if does anything else? In addition, if it will affect my planed engine swap?
Old March 23rd, 2005, 08:40
HoratioTheJeep's Avatar
HoratioTheJeep HoratioTheJeep is offline
Re: Extended Idle???
Actually, my understanding of the ext. idle was that it was used for boosting electrical power, things like jumpstarting people's cars (in fact a cop once did this for me--I'd totally killed my battery & first he tried to jump it without high idle, tried a couple more things & finally had to turn on the ext. idle). Off-roaders tend to use them for powering winches, OBA, etc. It seems like a nice feature to have. Also, those police pkg XJs came with better wiring than stock street vehicles.
I don't know that it will affect your engine swap. If you're keeping your existing wiring harness it should work the same way it did before. But if you have to swap in a new harness to go with the engine, then there might be some difference, I don't know for certain.
Rate This Thread:
WTB: Driver side vent, overhead console, and an extended idle switch bezel 90Pioneer Wanted: Private Party Only 1 January 30th, 2005 13:54
WTB: Factory Extended Idle switch bezel for pre 97 XJ 90Pioneer Wanted: Private Party Only 5 October 3rd, 2004 17:27
Studder at idle jeepster1985 OEM Tech Discussion 2 December 9th, 2003 02:35
engine idle Fletchs90xj OEM Tech Discussion 2 October 22nd, 2003 23:27
Random Idle Speeds BenXJCA OEM Tech Discussion 1 April 1st, 2003 16:41
