Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > Wanted: Private Party Only
Wanted: Private Party Only Post what you are looking for. If it even smells commercial, your ad will be deleted.
Old September 14th, 2004, 20:38
90Pioneer 90Pioneer is offline
WTB: Factory Extended Idle switch bezel for pre 97 XJ
I am looking for a factory extended idle switch bezel that'll fit right into my 1996 Jeep Cherokee. They came on XJs with the Police Package. I believe anything from '87 to '96 will work.
I will pay a good price. I also have a couple fog light switch bezels if you are interested in trading.
cbrons1@comcast.net
Thanks
Old September 17th, 2004, 08:41
Spanky414 Spanky414 is offline
Re: WTB: Factory Extended Idle switch bezel for pre 97 XJ
I don't want the original switch but I thought I had seen some instuctions on how to do this yourself somewhere, does anyone have a link? How high does it idle with this setup?
I was thinking for OBA and during winching operations.
Old September 17th, 2004, 18:02
imma honky's Avatar
imma honky imma honky is offline
You can install a hand throttle to do the same thing. Or if you are good with servos and such it can be done electronically.
Old September 17th, 2004, 21:07
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
I tried to find the bezel a few months ago and didn't have any luck. The factory part has been discontinued and I couldn't find any used bezels either. I just took a razor blade and cut out the plastic cover from the hole in the original blank bezel and put the new switch in the hole. The switch ground a wire that hooks directly to the engine controller through the P/S pressure switch input pin. It raises the idle to around 1100rpm when in park or neutral when the pin is grounded.
Bryan
Old September 27th, 2004, 20:54
Bump
Old October 3rd, 2004, 17:27
bump
98 XJ Driving Light Switch question Boris T OEM Tech Discussion 16 June 18th, 2004 07:13
WTB factory service manual for 90 xj lapaul Wanted: Private Party Only 0 April 9th, 2004 12:27
95' stock xj in NorCal for sale--make offer Big Red Sierra Chapter 0 December 7th, 2003 12:29
WTB radio/cassette deck for 1990 xj lapaul Wanted: Private Party Only 1 October 13th, 2003 05:36
96 xj rough idle( winded explaination ) anaheimxj OEM Tech Discussion 4 July 30th, 2003 11:53
