Old March 1st, 2012, 09:03
old_man's Avatar
old_man old_man is offline
Rebuilt Steering Gears
I rebuild a ton of steering gears for guys on here and port them. Lately I have had a hard time finding enough cores. I bit the bullet and went and bought 3 reman'd units from my local auto parts store. I pulled them completely apart and drilled and tapped them. When I went to put them back together I found that none of the three boxes had the right number of recirculating balls. There are supposed to be 12 large and 12 small. No box had more than 23 balls with one only having 21 and the numbers of large and small were random. Luckily I have a supply of the balls and was able to get them set up correctly, but beware of the shoddy work being done, most likely in China.
Also none of the bearings had been replaced. You can tell the original bearings from the newer ones.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old March 1st, 2012, 16:10
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Rebuilt Steering Gears
I'm glad yours has more balls than theirs.
Is this one of the generic auto parts, or a high dollar store?
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 1st, 2012, 19:10
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
Curious as to who reman'd them.
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old March 1st, 2012, 19:37
ktwalker01's Avatar
ktwalker01 ktwalker01 is offline
good job on the ball supply!
Old March 2nd, 2012, 06:14
old_man's Avatar
This was Autozone.
Old March 2nd, 2012, 06:20
Justpunchit's Avatar
Justpunchit Justpunchit is offline
NAXJA Member #1291
go figure... I ported an autozone one... never looked at how many balls were inside.
Old March 2nd, 2012, 06:21
Ronbo's Avatar
Ronbo Ronbo is offline
Originally Posted by old_man View Post
This was Autozone.
But they have a lifetime warrantee!!!! - haha.
Old March 2nd, 2012, 06:22
old_man's Avatar
I hope you at least took it apart after you drilled it out. Did you alternate the large and small ball when you put it back together?
Old March 2nd, 2012, 06:23
old_man's Avatar
Like they are going to do that after I punch a couple of holes in it
Old March 2nd, 2012, 06:37
NAXJA Member #1291
I think i did. I followed a billavista write up on it IIRC.
You'd be surprised on what AZ takes back.. I've had take them back GM alternators to warranty out my jeep ones. Yj radiators for XJ's. Most of the help out my way gets paid maybe 9 bucks an hour to work the counter. They just care it's a part that goes in a box back to the DC.
Rebuilt steering gear choices cherokeefan_1 Modified Tech Discussion 19 December 12th, 2011 16:00
Rebuilt power steering pump VS new pakkman OEM Tech Discussion 1 September 30th, 2010 11:57
For those of you who have rebuilt your steering boxes.... YELLAHEEP Modified Tech Discussion 11 March 7th, 2004 10:56
