Old November 20th, 2020, 21:58
NOTNSUV's Avatar
NOTNSUV NOTNSUV is online now
You Guys ROCK!
Re: Improving ride on a DPG OME lift
Originally Posted by IslanderOffRoad View Post
Looks not great. Should be 45 degrees or so back, you’re not quite 90, maybe 70 or so.
SRB go in tomorrow hopefully.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 21st, 2020, 09:58
RCP Phx RCP Phx is offline
Got to say those RC brackets look scary as hell like most of their products, the SFR brackets are pure beef!
Old November 22nd, 2020, 00:36
NOTNSUV's Avatar
You Guys ROCK!
Scary? As in, "HOLY SHIT, somebody's gonna die!" scary?
Yup, if I wanted to spend additional money and take the time for box removal, instead of using a product I've had on the shelf NIB for 10 years, I'd go with the SFR. Apples and oranges maybe? Lift/no lift, bolt in or massage/remove the buckets.
They're both a chunk of 3/16" (or so) steel, bolted to aftermarket nut-strips in what appears to be at least 3 places, both engineered to do a simple task - and my guess is I won't be breaking either with my driving style.
I always appreciate input but please elaborate instead of just dropping a stink bug.
Enlighten me please, I'm subject to persuasion.
Old November 22nd, 2020, 05:26
Death type "scary", the RC kit only bolts on sheet metal with a few bolts. The adjustment rail only bolts on with a couple small bolts all in the same "plane". All that height just adds leverage on that weak material and those few bolts.
Old November 22nd, 2020, 08:14
maxbraketorque maxbraketorque is offline
I would do a no-lift shackle for sure. As the shackle mount moves further from the body, the ability of the bracket to resist side-to-side bending (think about your XJ parked sideways on a hill) is reduced. It becomes more of a problem if the bracket is made of relatively thin metal. This will add instability to the handling.
And the additional lift makes it more difficult to use an OTS leaf spring. Your goal is to be able to run a longer leaf spring that provides more wheel travel, but you will be challenged to find a OTS long leaf spring that provides minimal lift needed to maintain your target lift of 3.5-4.5".
Old November 22nd, 2020, 09:34
NOTNSUV's Avatar
You Guys ROCK!
So, I didn't even know the brand SRB I had in hand and was watching the RC video for a general idea of mounting. I've now ID'd my SRB as Ironman 4x4 Fab. "These Relocation Brackets are made from 5/16" 100,000 psi Domex steel."
https://ironman4x4fab.com/products/x...ation-brackets
Should I feel better now?
Old November 22nd, 2020, 09:45
NOTNSUV's Avatar
You Guys ROCK!
If I replace rear springs it will be these:
https://www.ironrockoffroad.com/Merc...t_C ode=10437
And they say this: "IMPORTANT PRODUCT NOTE: These springs are longer than the OEM springs. Because of their length, they will require the use of either a lift shackle, boomerang style shackle, or shackle drop/relocation kit."
Not sure if one is preferred over the other.
If I use only the lift shackles I already have I could well end up with a crap angle still, correct?
Boomerang less than ideal?
SRB + stock shackles?
Old November 22nd, 2020, 10:22
NOTNSUV's Avatar
You Guys ROCK!
I hope the OP (Roryd89) is getting some worthwhile information from his thread that I seem to have hijacked. Looks like we're in the same boat so to speak.
Old November 22nd, 2020, 10:27
Any of the SRBs will allow you to use a non-boomerang shackle, and you should be able to adjust the angle to the range that people like to recommend. But that shackle box will raise the rear about 1" all by itself. A longer shackle, even at a 45 degree angle will add some lift too. So with a "lifted SRB" + aftermarket shackles, total lift will be at least 4.5", and will probably be closer to 5-5.5" inches.
Old November 23rd, 2020, 13:02
Roryd89 Roryd89 is offline
haha i am! im glad you're getting some help as well!
Old November 24th, 2020, 08:09
bentroia bentroia is offline
My 97 with DPG kit has the OME med springs front and rear with their sport shocks. Goodyear wrangler adventure 31s at 28 lbs. It rides firm but not harsh at all with no added weight on the vehicle. Shackles are stock.
Is thrre binding somewhere? Has everything been loosened and re torqued weighted at ride height? Are bushings tge require lube lubed?
Old November 24th, 2020, 10:23
NOTNSUV's Avatar
You Guys ROCK!
Looking hard at the Iron Rock 3.5" springs.
"“IMPORTANT PRODUCT NOTE: These springs are longer than the OEM springs. Because of their length, they will require the use of either a lift shackle, boomerang style shackle, or shackle drop/relocation kit.”
I've asked IRO which they prefer so waiting on them.
From your comments I would guess no-lift SRB would be the ticket. With OEM shackles? Or is there an aftermarket OEM length shackle that's an upgrade?
They also offer 'add-a-leaf' to the spring set for additional load capacity and "adds lift", so I also asked how much of each.
Old November 24th, 2020, 12:15
Stock shackles are too short for a long travel lifted leaf spring. If you are looking for minimal lift (0.75" if the shackle was vertical), then Rusty's are nice. Very beefy and fit well. I tried to use the IRO 0.75" lift shackle, but it didn't fit well, and it was not nearly as beefy as Rusty's. If you want more lift from the shackle, then many can be considered.
Old November 24th, 2020, 12:21
Also, keep in mind that if the shackle is angled at 45 degrees, then the amount of lift provided by the shackle will be 70% of what the advertised lift will be.
Old November 24th, 2020, 15:01
NOTNSUV's Avatar
You Guys ROCK!
Thanks for the reminder. As you well know, I'm all over the place on this. I'd looked at Rusty's earlier and forgot about'em. A great option to dial in the lift height. I'm not looking for a lift number, but a look and feel.
https://www.rustysoffroad.com/jeep-s...able-pair.html
Planning on a mild group trail run Sunday so can feel it out with only the lift shackles in place compared to before. Might have an opportunity to hit some tougher stuff offroad. I'll take it from there but if I feel good about the ride and don't see an issue with the OME springs I'll try to leave it as is.
Any concerns with gas tank skid and JCR bumper if/when the SRB go in? As in, getting SRB mounted under the skid mount which is preferred so as to not add even more lift. Not sure if it will change my bumper position. Figure it out when I get there.
Improving MPG SEXJ96 OEM Tech Discussion 16 August 17th, 2018 21:04
Improving rear suspension ride quality AZ XJ Modified Tech Discussion 22 September 20th, 2009 22:08
air-ride lift?? DeezUU Modified Tech Discussion 12 April 12th, 2007 02:19
Improving MPG RichP Non-Tech / Off Topic 10 October 5th, 2005 21:10
lift ride tony r Modified Tech Discussion 11 April 22nd, 2004 14:44
