Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#61
Re: Booster Upgrade
Hey,
thank you so much for your answer so do you think the BLA-G360 / BLA-R340 / BLF-31B / BLF-33B that I bought are not okay ? thank you Giacomo |
#62
Re: Booster Upgrade
If its not your daily I would also check and make sure your fittings arn't frozen in the proportioning valve. If they are you will have to take another path with the connections. |
#63
Re: Booster Upgrade
Might also pick up a brake line bending tool and some flare nut wrenches. They will make your life easier.
#64
Re: Booster Upgrade
" If they are you will have to take another path with the connections."
that is, what should I have in stock ? thank you Giacomo |
#65
Re: Booster Upgrade
Thank you jeepboy12001
so if i buy 2 flexi lines (52128086/52128087) which fittings should i use to connect the hoses to the proportioning valve ? Giacomo |
#66
Re: Booster Upgrade
Hi all,
nobody knows which fittings I have to buy for connect the 2 flexi lines to the proportioning valve ? thank you Giacomo |
#67
Re: Booster Upgrade
Hi all,
update of problem, in the end I to fit the 2000 WJ master cylinder and brake booster with the fittings and tubes that I described a few posts ago, with new rear brake drums and new brake cylinders the braking has improved considerably, but the brake pedal has a too long stroke, it acts only in the last part of its stroke. is this normal or can I do something ? how can i attach pics ? thank you Giacomo |
#68
Re: Booster Upgrade
adjust up the rear brake shoes first. Perhaps re-bleed the system.
#69
Re: Booster Upgrade
Already adjusted the rear brake shoes, in fact now the wheel is slightly braked....
do you know how to attach pics ? thank you Giacomo |
#70
Re: Booster Upgrade
Have you bled the brakes again?
RR,LR,RF,LF |
#71
Re: Booster Upgrade
bleeding done 3/4 times...
Giacomo |
#72
Re: Booster Upgrade
Did you bleed the master cylinder first?
#73
Re: Booster Upgrade
Yes on bench....
Giacomo |
#74
Re: Booster Upgrade
Hi all,
as already mentioned, the swap has brought about a 100% improvement in braking (even if in the first part of the brake pedal stroke there is no effect) but now I no longer have the rear brake lights ... brake light switch or an adjustment problem of the same on the brake booster rod ? thank you Giacomo |
#75
Re: Booster Upgrade
I also saw that there is another white switch on the brake pedal, on the top what is its function ?
could it possibly be used for the rear stop lights ? Giacomo |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Booster upgrade ! | PMGaming101 | Modified Tech Discussion | 10 | October 13th, 2014 05:16 |
Brake upgrade question non-abs booster to abs booster | 94xjstud | Modified Tech Discussion | 3 | February 3rd, 2010 09:12 |
99 Brake Booster Upgrade!!!! | AZRockRunner | Arizona Chapter | 0 | May 8th, 2007 20:47 |
WJ brake/booster upgrade,.. | bxj | Modified Tech Discussion | 0 | August 25th, 2006 21:11 |
Upgrade to 95 booster,M/C | redwagon | Modified Tech Discussion | 8 | September 17th, 2003 16:50 |
