Two questions here, actually.
I just installed a Daystar poly transmission mount over the weekend because mine had been broken for years, and unforunately I should have done some research on this issue before purchasing it. Little did I know, these suckers are taller than the OEM style and now I'm hearing a loud rattle or grinding noise at random intervals with the engine running (whether in neutral or in gear.) I'm guessing this is due to the taller mount and I would need to drop the cross-member to correct this?
Either way, because I'm going to be installing a 5 inch lift next month I'm afraid I'm going to have to ditch the whole extra-tall poly mount idea and stick with the OEM rubber style. My only concern is: would I be losing any amount of power due to the flex of the rubber mount? Do the poly mounts offer less power-loss?
