Old June 16th, 2009, 19:16
XJunky XJunky is offline
High Fuel Pressure
Been having a problem with a 1996 XJ 4.0. It runs fine until it is warmed up, and then it starts hesitating and has no power at operating temp.I replaced the fuel pump and the filter on the frame rail to no avail. Just bought a gauge today to test fuel pressure. With the key in the on position it sits at 48psi, but when I start the jeep it jumps up to 60-62psi and the gauge jumps erratically. Is this pressure too high? My other XJ runs at 49psi.
Old June 17th, 2009, 08:13
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Re: High Fuel Pressure
Fuel pressure does sound too high. Can't recall but what is the "regulator" setup on a 1996? Is it separate from the pump? I'd be a bit suspect of that piece of hardware.
A field service manual would provide you with comprehensive fuel pressure testing to help you isolate root cause. You've got the gauge; I'd find an FSM and do some more testing.
Fuel Pressure too High. ajporter03 OEM Tech Discussion 0 April 8th, 2008 18:15
Fuel pressure too high? alky350 OEM Tech Discussion 2 February 22nd, 2006 12:19
Fuel pressure too high my65289stang OEM Tech Discussion 4 January 14th, 2006 03:24
High Oil Pressure BSD OEM Tech Discussion 2 June 7th, 2005 20:01
High Oil Pressure? Andy73 OEM Tech Discussion 4 August 15th, 2003 08:07
