Old April 8th, 2008, 18:15
ajporter03's Avatar
ajporter03 ajporter03 is offline
Fuel Pressure too High.
I have been getting pretty poor gas mileage lately. And I think that I might have found the problem. My fuel pressure seems to be too high. At idle with the vacuum line connected I get 39 psi. With the vacuum line disconnected I am up near 45 to 47 psi. The haynes book says to check for a blocked return line. I couldn't find any problems. So I disconnected the return line right at the fuel rail and hooked a line straight into a gas can. No change. I am pretty sure that I need a new regulator, but before I bought one, I just wanted some opinions.
It is a 93 XJ 4.0 aw4. I am pretty sure that the fuel pressure should be 31 at idle vacuum line connected and 39 with it disconnected.
High Oil Pressure jeepman121 OEM Tech Discussion 5 December 17th, 2007 19:42
high pressure SUA SPONTE OEM Tech Discussion 2 June 20th, 2007 05:50
high oil pressure okreno OEM Tech Discussion 15 January 9th, 2007 06:03
Fuel pressure too high? alky350 OEM Tech Discussion 2 February 22nd, 2006 12:19
Fuel pressure too high my65289stang OEM Tech Discussion 4 January 14th, 2006 03:24
