riverfever said:
Why did you go with a short AAL? Not ot be an a$$ but it's not a great idear.
Who cares...:confused1
Here's the instructions on installing any short AAL.
He will need:
* floor jack
* set of Jackstands
* 1/2" Drive 3/4" deep socket or air tools. Also a Vice-Grips and whatever size wrench fits the nut on the new centering bolt.
* large "C" clamp. Not some pussy C-Clamp, but one big honking serious C-Clamp.
* Some common sense.
Roughed out procedure:
* Jack up vehicle untill the tires clear the floor by a good 2" and put jackstands under the flat area infront of the forward rear spring perch.
* Remove tires
* Lower vehicle untill the frame rests on the jack stands, but do not let the axle drop just yet.
* Remove the nut holding the shocks to the bottom mount at the axle, and remove the shock from only the lower mount.
* Soak U-bolts with Blaster and let sit a few minutes, then loosen and remove the u-bolts from one side. The axle on that side will drop a bit when you remove the U-Bolts and lower the jack.
* Put the C-Clamp near the middle of the springs arch and remove/cut the centering bolt on the spring pack. Note lengths and orientation of spring leaves, and loosen the C-Clamp.
* Install the AAL one leaf up from the bottom (or just below the next longer leaf) using new centering bolt as a guide, and re-apply the C-Clamp and clamp down spring pack untill it is completely compressed in the middle. The centering bolt should be able to move vertically in the back at this point.
* Tighten the centering bolt as tight as you can get it. Head side should be down.
* Release C-Clamp and put your jack under that side of the axle. Lift axle into place using the jack (I'm lazy) so that the centering bolt's head goes in the centering hole in the perch.
* Install the U-Bolts tightening them equally untill they are cinched up. Then tighten in a X pattern, the bolts to 20, then 50, then 70 ftlbs.
* Do other side.
* Jack the axle up a bit and install the shocks.
* Jack vehicle back up, install the tires and remove the jackstands.
