Old April 16th, 2018, 13:52
Xplorer400 Xplorer400 is offline
Interchangeability question
I bought a rust free 2000 with what I now believe to be a trashed engine ant trans. It started but wouldn't move and made so many different noises it was impossible to tell what was going on. Got rid of some noises but after further inspection believe neither is worth fixing. Both have over 200k miles, so not a big surprise. What years would be a direct swap and how difficult is it to swap? I was told to do it as a whole unit, is that correct? Any help would be much appreciated.
Old April 16th, 2018, 14:24
RCP Phx RCP Phx is offline
Re: Interchangeability question
2000-01 are the only "direct" fits!
Old April 16th, 2018, 15:16
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0 L engine block will interchange.
Remove and re-use ( or replace with new ) as needed or required from your original engine: Intake/Exhaust manifolds, throttle body, flex plate/flywheel, cylinder head, water pump, distributor-less ignition or distributor assembly, OBD engine computer sensors, fan belt driven accessories, and/or mounting brackets. Difficulty depends on your skill level/experience and your available tools.
If your 2000-2001 XJ Cherokee has a cracked 0331 head, buy a good used redesigned and more durable TUPY 0331 head from a 2002+ 4.0L TJ Wrangler or WJ Grand Cherokee.
Read this thread about AW-4 transmission swapping >> http://www.naxja.org/forum/showthread.php?t=1053970
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old April 16th, 2018, 17:16
I need to check for the notorious crack in the cyl. head, but judging by what the coolant system looks like, my guess is that it is cracked. Thank you for the quick and expert response.
Old April 16th, 2018, 18:43
Heavyopp Heavyopp is offline
Is your 2000 federal or cali emissions? Do you have the 2 pre-cats under the hood?
Old April 16th, 2018, 19:15
alexgalexg's Avatar
alexgalexg alexgalexg is offline
You should try to use 99 or older parts. Trans and engine is the same just more reliable because Chrysler didn't run AMC design by using cheap materials until 00. May have to use your sensors, injectors and intake from the original engine. Only thing I'm not sure is how the coil pack transfers over but it was better with a distributor anyways since the coil pack Chrysler slapped on was lack luster
Old April 16th, 2018, 21:47
lawsoncl lawsoncl is offline
AW4 transmission interchangeability would be 1998-2001, which are all likely to have similar mileage. The AW4 is fairly robust and 200k miles isn't that high. Could be a simple problem.
Old April 17th, 2018, 03:30
Well, when I looked at it 1st, noticed that the was a ton of P/S fluid leaking and the trans cross member was dripping ATF. Figured it might have been run low enough to cause it to stop moving. When I got it home and checked it properly, found it over filled with new fluid. Figured it was toast at that point.
Old April 17th, 2018, 05:46
alexgalexg's Avatar
Try draining some out of the pan. Might be alright
Old April 17th, 2018, 20:10
Check the tranny cooler lines. Sometimes the metal clips holding it to the oilpan wear through the line and they start leaking. Also make sure you're checking with the tranny at operating temp in neutral with the engine running and the parking brake set.
Old April 18th, 2018, 10:21
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
00-01 as stated is what you can drop in, past that It become a pain to start swapping over other engine parts. I dumped my 01 project after starting to see how difficult it was going to be to swap over my 93 parts. You have Coil on plug, 2 cats, intake manifold is slightly different, same with exhaust. Yes, you can swap stuff over but was more work than I wanted to put in to mine. Trans 98+ is the best earlier years can be swapped but a gain a lot more work.
VSS interchangeability? themauler OEM Tech Discussion 0 February 17th, 2014 11:52
01 WJ interchangeability? terryd Modified Tech Discussion 15 December 22nd, 2010 18:04
AW4 interchangeability 1988JeepXj OEM Tech Discussion 9 September 10th, 2010 08:03
seat belt interchangeability question Me007gold OEM Tech Discussion 4 February 2nd, 2009 18:13
TJ/XJ Control Arm Interchangeability xjh3 Modified Tech Discussion 5 December 27th, 2007 17:03
