Old June 13th, 2016, 12:53
waxer's Avatar
waxer waxer is offline
Fuel rail leak from unknown part
Forgive the ignorance on the name of this part, but I recently started up my 92 XJ after sitting for about 8 years. After going through every system and replacing or confirming good operation, the only issue I see is the fuel rail is leaking from this component.
What is this component called? Is there an o-ring or a gasket underneath it?
Thanks in advance
Old June 13th, 2016, 13:09
waxer's Avatar
Re: Fuel rail leak from unknown part
Disregard. Found through further research that this is the fuel pressure regulator. It must have dry rotted o-rings inside of it. I'm going to take it apart and see if I can replace the o-rings. If that doesn't work, I might as well get a new one.
Old September 15th, 2016, 16:14
RideBlue RideBlue is offline
were you able to find the O-rings? I have failed to find them at the parts houses. Dealer?
Old September 15th, 2016, 22:04
Tin Man Tin Man is offline
Just get the Dorman o ring assortment package for fuel systems, you will find the correct one in there, as well as others you can use for the motor. I just replaced my regulator o ring last weekend with the kit.
Old September 16th, 2016, 06:53
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
As far as I know there are no o'rings on the FPR itself. There are o'rings on the inlet and outlet connections. And the FPR itself can go bad internally and leak fuel into the vacuum line on the left side. If the FPR casing is leaking it it not repairable. Hard to tell from the picture where the leak is from.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old September 16th, 2016, 09:00
lawagoneer lawagoneer is offline
I got my new regulator for my '89 from the dealer, came with the o-ring. The parts guy said they still had fuel rail service kits with just the o-rings available if that was all I needed.
Old September 16th, 2016, 21:50
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
The "quik-disconnect" needs two O-rings and a spacer, if you take it off, save the plastic spacer. Then take an o-ring to ACE hardware and match it up. The "part" to seal the quik-disco (2 O-rings and a spacer) costs $8.95 + shipping, each connector. O-rings cost under a buck each.
The regulator to rail o-ring is just a single o-ring. it just pops on, then bolt to secure.
Old April 16th, 2018, 11:28
HI-CNTRD HI-CNTRD is offline
Thanks for all the information guys! I have an 1990 Cherokee with the I6. The dealership has the part number as 83502746 which I crossed matched it to Napa’s number CRB 2-12305. It was $25.99 but came with all the peices and fixed my problem!
Old April 16th, 2018, 11:30
Sorry it was $15.99 at Napa
fuel rail leak? egotripp OEM Tech Discussion 26 July 18th, 2016 20:44
renix fuel rail leak 87woody-atl OEM Tech Discussion 22 December 15th, 2010 13:35
Fuel Leak at Rail joejeep92 OEM Tech Discussion 10 July 15th, 2010 17:54
Fuel Rail Leak - HELP 01whiteXJ OEM Tech Discussion 12 June 20th, 2010 19:35
89 xj fuel rail leak bcmaxx OEM Tech Discussion 2 November 28th, 2006 11:31
