Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
  #271
Old December 5th, 2021, 21:13
Nates2000XJ's Avatar
Nates2000XJ Nates2000XJ is offline
Re: XJ axle swap/build
Originally Posted by DocTremp View Post
That’s a good idea, I have some PVC lying around from my mock up links. For squaring your axle to the body, what landmarks did you measure from?
Thanks, I’ll check them out.
hang the leaf springs and measure from outside face of the leaf pack to the inside face of the axle flange. You can measure from a bunch of things but leaf to flange seems to be one of the most reliable places to reference on each side. I did not account for the 1-2 degree compensation Rob mentioned. For what its worth, I haven't encountered leaf wrap symptoms. If I did, I'd look into an anti wrap bar before cutting off the U bolt eliminators and re-doing them.
Old December 6th, 2021, 16:11
DocTremp DocTremp is offline
XJ axle swap/build
Got it, thanks Nate. That makes a lot of sense. I’ve read in other threads about angling pinion 1-2 degrees, but I’ve heard from both sides that their set ups work without issue. I think it may be preference? Idk.
Old December 6th, 2021, 21:40
Maybe. May be spring stiffness, gear ratio/final drive ratios. I'd have to think on it and draw force vectors or something.
Old December 7th, 2021, 06:14
maxbraketorque maxbraketorque is offline
The notion of angling the pinion down 1-2 deg relative to the drive shaft is to compensate for axle wrap. For sure there is no reason to make the pinion shaft parallel to the drive shaft. Only question is how much to angle it down. Adams recommends 1-2 deg.
Old December 7th, 2021, 16:21
XJ axle swap/build
Aww man, take it easy with those force vectors haha. I enjoyed that part of physics, but I don’t use them too often anymore. I think spring stiffness if probably it, but I’m sure hear ratios have something to do with it as well.
Old December 7th, 2021, 16:28
XJ axle swap/build
I got ya. Sounds like that’s if you’re running leaf springs without a torsion bar, which is what I am doing, but I’d rather add a torsion bar to fix the axle wrap then change my pinion angle. The point of your pinion being parallel to the drive shaft is to limit vibration I believe.
Old December 7th, 2021, 21:52
Actually, the angle needs to be slightly off parallel to drive the needle bearings in the u-joint to circulate. 1-2 deg (or maybe 1-1.5 deg) off parallel should be the target whether or not you plan to limit axle wrap with torsion bars.
Old December 8th, 2021, 12:52
XJ axle swap/build
I got ya, if the needle bearing don’t move then the life of the u joint is reduced. Thanks for the input.
Old December 13th, 2021, 03:19
89Mock 89Mock is offline
I did my Sterling 1.25 using the ruff stuff +2 perches. Angle the pinion down 2 degrees. Part of the reason is so the u joints get lubricated while they rotate. If they’re absolutely perfectly at zero they’ll burn up, but this won’t ever happen on our Jeeps. The pinion just moves up more than you’d think. At first I did mine without the full weight on the vehicle. Do yours with the new tires on all four corners. That’s what you’re going to be driving with so that’s what you should set it up with. I took as many measurements as I could before assuming the axle was centered.
Old January 20th, 2022, 11:56
XJ axle swap/build
For those of you who have done wider axles, what length did you go with brake lines? I have 22” now and I don’t think it’s enough. Iron rock has 27” front and 22” rear as a combo, ruff stuff has 30” fronts but no rear. Any advice would be awesome, thanks!
Old January 20th, 2022, 22:17
My fronts are Crown extended XJ steel braided lines. 5-6" lift size iirc I picked the longest ones they offered. They are plenty long, my shocks droop out before the brake lines do. The rears was the steel braided line from the Crown kit and I kept the rubber soft and hard lines from my ZJ brake set up on the stock axles. I ended up needing to ream out the banjo fittings on the caliper side of the brake lines since the larger brakes used a larger dia banjo bolt. My larger brakes also benefitted from a larger master cylinder but that's not really related to lines. I'll try to post a photo or two
Old January 21st, 2022, 11:51
XJ axle swap/build
Thanks Nate! I have 4-6 inch lift extended brake lines from RE and I wasn’t sure if they’d be long enough. I think I might just run them and see what stops the flexing first.
What MC did you end up running BTW?
Old January 23rd, 2022, 11:41
Phil's Avatar
Phil Phil is offline
Have you relocated or removed the lower brake line clip on the body?
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old January 23rd, 2022, 20:52
Centric: 131.67025
Amazon link below. Look on Rockauto or other sites to find the best deal.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old January 23rd, 2022, 20:55
XJ axle swap/build
I pulled them off for frame stiffeners and I have yet to relocate them.
Rate This Thread:
93 XJ BUILD (WITH LS SWAP) 92xjRJ Modified Tech Discussion 89 August 17th, 2020 09:35
93 XJ BUILD (WITH LS SWAP) 92xjRJ Modified Tech Discussion 0 May 5th, 2017 11:21
88 MJ Build / Axle Swap with Q's laxbro37 Jeep Comanche MJ (1985 - 1992) 3 January 31st, 2017 06:35
My build... long arm lift, JK axle swap, stiffeners, whole 9 yards MfeMorley Modified Tech Discussion 26 January 6th, 2017 14:43
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
