I have re-written my write up on locking out first gear so you can stay in 2nd and slow up enough without getting thrown forward when the auto wants to use 1st instead.
I also added a write up on how to lock your torque converter so that you can get better engine braking on those slippery steep hills where using your foot brake will only speed you up and cause you to loose steering control. I only see this mod for emergency use as the torque converter lock is not designed to have high loads on it or any load coming from the wheels instead of the engine.
See my site under the electrical section of the index.
www.go.jeep-xj.info
www.go.jeep-xj.info
