Old June 18th, 2017, 00:00
moparcyco moparcyco is offline
Renix 242 speedo question
Spent the last few hours helping a friend change the transmission in his 90 XJ. We put in a 93 AW4 and 231 from same. I did not realize the Renix uses a damn speedo cable. Can you just unbolt the cable adapter from the 242 and put it on the 231? write-ups? I looked for a minute but I'm tired as hell. Thanks guys
Old June 18th, 2017, 10:06
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Renix 242 speedo question
I believe so.
Old June 18th, 2017, 20:20
bigdaddyjlove bigdaddyjlove is offline
you absolutely can. i have a renix aw4/242 in a 96. pull the cable, swap the gear over (roll pin) and it drops right in.
Old June 19th, 2017, 12:02
ehall's Avatar
ehall ehall is offline
pull the sender out of the old transfer case and move it to the new case--hole size is the same
my '91 beater rebuild
speedo question redneckstylin Modified Tech Discussion 5 July 22nd, 2010 10:26
Speedo and Odometer Question cj11 Modified Tech Discussion 11 October 3rd, 2009 17:37
speedo on 231 question jephs422 Modified Tech Discussion 4 May 18th, 2005 06:59
91 Speedo question CustomCab OEM Tech Discussion 8 November 17th, 2003 18:38
Speedo question MuddyXJ OEM Tech Discussion 4 April 24th, 2003 06:50
