Old June 15th, 2017, 04:51
PalmettoOne's Avatar
PalmettoOne PalmettoOne is offline
LED Fog Lamps
Now that I've wasted my money on LEDS that won't work in my 98 XJ...I need to ask a question that I'm sure has been asked before.
Is there a good direct LED replacement for the stock fog lamps....that won't drive my mechanic crazy trying to make it work?
Thanks in advance!
Old June 15th, 2017, 05:53
Redsnake Redsnake is offline
Re: LED Fog Lamps
I'd like to know the same... I have a set of LED headlights that I'm running on my '01 XJ that I like but still have the OE bulbs in my stock fog lights.
Old June 15th, 2017, 06:16
CarbonXJ's Avatar
CarbonXJ CarbonXJ is offline
Re: LED Fog Lamps
LEDs in the stock fog light housing would be crap. The housing, which is a nicely made, is not designed for LED bulbs. You would just scatter light everywhere, and possibly reduce your visibility, and definitely blind other drivers. The low mounting points of fogs are by design to light up a small section of road in front and larger section to the sides with a narrow beam during foul weather.
Best thing you can do is make a relay harness for them, just like a headlight harness. Follow that up with some quality 55w bulbs. I created a harness and had some Hella yellow bulbs shipped from relatives in Germany, and they are now amazing foul weather lights. Cost less than $35 to boot.
Old June 15th, 2017, 06:24
Re: LED Fog Lamps
I don't disagree that the OE Housings would be a bad idea for LED bulbs... nice idea you have. Part of the reason I've not really messed w/the OE fogs is because I've always planned on replacing the front bumper w/something else that would remove the OE fog lights all together. Then maybe I can add in some nice round LED driving lights to the aftermarket bumper... but that's still somewhere down the road for me.
Old June 15th, 2017, 09:41
Hopkins Hopkins is offline
Re: LED Fog Lamps
Why LEDs no work on your 98?
I had a problem running LEDs in my 98. They were causing some dash lights to be partially lit and high beams were stuck on. Once I pulled the fog light relay in the fuse box under the hood, all was fixed and LEDs worked like a charm.
Old June 15th, 2017, 11:39
trippled trippled is offline
Re: LED Fog Lamps
X2. Im not against LEDs, but I think halogens in quality housings can make better more focused beams for lower cost.
Old June 16th, 2017, 03:50
Re: LED Fog Lamps
Thanks for all the help. Looks like I'll stay with OEM. Lesson learned!
Old June 16th, 2017, 12:39
burntkat burntkat is offline
NAXJA Member #1145
Re: LED Fog Lamps
This!
I've been there and done that. It's a great idea to do for your headlights as well.
Why on earth would you pay a mechanic to install fog lights? It's VERY easy.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old June 16th, 2017, 12:40
NAXJA Member #1145
Re: LED Fog Lamps
If you pulled the relay, how on earth did you get the fog lights to work?
Magic?
Old June 18th, 2017, 03:58
Re: LED Fog Lamps
Got a broken ankle...aint gonna be bending, crouching and crawling under that bumper!
XJ: 87 Wagoneer - Fog Lamps? Crist Clapper OEM Tech Discussion 2 September 20th, 2012 09:21
1987 XJ: Which fog-lamps Crist Clapper OEM Tech Discussion 2 March 18th, 2012 05:42
led rock lamps bcmaxx Modified Tech Discussion 22 April 23rd, 2010 08:12
Tail lamps thecozmo65 OEM Tech Discussion 2 November 1st, 2005 15:50
Fog Lamps Vertisce Intermountain Chapter 12 October 22nd, 2005 16:57
