Old June 11th, 2017, 19:23
jmg222 jmg222 is offline
just got black magic brakes + new booster/MC and... no change?!?!
I just upgrade the brakes on my 1988, stock d35 with vanco's black magic 15" kit. At the same time, I had the shop replace the MC/booster with a setup from a 1995.
driving around town, I notice virtually no difference. Ok, it really didn't stop terribly, and I did go from 31" to 35" tires, so maybe there is an improvement. the reason I did all this was because on the trails, in 4lo, if I'm going down a hill (or up, and need to back down), the hill + motor idle was often enough to overcome the brakes.
Anyway, I put the truck in 4lo .. on pavement, but just driving straight, and from stop hit the brakes and gas. at around 1200-1500 rpm, not much at all, the truck overcame the brakes.
IS this normal? Is 4lo just too much for my brake setup (I have a ford 8.8 with stock drums in the rear).
I tried bleeding the brakes -- is there any trick to it? I'm terrible with brakes, but pretty sure I did this right -- Put a screw-in reservoir on top of the fill tank on the MC, filled with brake fluid, and Used a pneumatic vacuum-puller -- started with RR, LR, RF, LF. pulled like a quart of fluid.
Other than bringing this back to the shop, anything I can try myself?
Daily drive: 2018 Jeep Grand Cherokee Trackhawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: 350 sbc, crane cam, holly performer intake, Terminator EFI, novak shorty headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old June 11th, 2017, 22:06
Francesco Francesco is offline
Re: just got black magic brakes + new booster/MC and... no change?!?!
Adjusting brakes may make a difference, maybe a disc swap. Make sure your prop valve isn't clogged as well. Are you sure you swapped the better booster? I'm not too familiar with the XJ ones, as I swapped a WJ one onto my MJ, but I can lock up 4 35s, and I have stock brakes in the front still.
Old June 12th, 2017, 07:55
What do you mean? I'm using brand new discs from vanco
Yup.. the booster/mc on 95+ are completely different than 94 and earlier. totally different MC/res set up, and the booster is about twice as thick.
Old June 12th, 2017, 08:26
Vanimal Vanimal is offline
did you bed the brakes properly?
Old June 12th, 2017, 08:34
RWKHausSupply's Avatar
RWKHausSupply RWKHausSupply is offline
NAXJA Supporting Vendor
You should have used a WJ booster/master.
Did you break in (Bed) the pads, as BMB tell you to? How did you accomplish this? That did you do basically...
RWK Haus Supply
All your drivetrain And Jeep needs at a Discount! Call us for all your drivetrain & Jeep accessorry needs. If it is for a Jeep we can get it for less and with superior service. Yukon, USA Standard, Motive, Ten factory, Detroit, ARB, Teraflex, Rock Krawler & A LOT MORE..
All items ship FAST! ~ http://www.rwkhaussupply.com ~ Robert@RWKHausSupply.com Free shipping on Rock Krawler kits. Dana 30 no question asked 1yr warranty axle kits FOR LESS!
Old June 12th, 2017, 08:46
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I'll third the burnishing, if you don't break them in properly they never feel right.
I have the black magic pads on my xj (98 on 35's) with disc in the rear...stops better than a stock cherokee.
Praise Marty Moose!
Old June 12th, 2017, 12:59
nicpaige nicpaige is offline
Brake those pads and rotors in correctly and they have more than adequate stopping power. If they changed the booster did they get the shaft length correct?
Old June 12th, 2017, 13:26
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
I have run 15" Vanco kit for over a decade, the last five years with Black Magic pads and I love them. The BM pads work well cold or hot.
Blaine, the owner of Black Magic, suggests running new, premium rotors, along with the BM pads, for best performance.
Do follow the break in routine as shown in the instructions.
The BM pads like to be used hard occasionally to keep them from glazing, bedding is extremely important.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old June 12th, 2017, 14:14
N8N_99xj N8N_99xj is offline
Did you check the rear brakes?
My '99 passed inspection for two years in a row and I thought the brakes sucked until one night the pedal started sinking on me... came to find out that one piston was froze up on each rear wheel cylinder. Redid the rear brakes (along with some finagling to actually get the self adjusters to work properly) and they were much improved after that.
Old June 12th, 2017, 14:51
Why?
yup. to the T.
Old June 12th, 2017, 14:54
Rear brakes are new also -- just finished putting in a ford 8.8.
I'm brining it down to a shop tomorrow, I'll have them check everything over to make sure.
I'll also re-do the brake in procedure. I have less than 50 miles on the brakes, so I hope if I didn't do it properly the first time I didn't cause any damage.
Old June 12th, 2017, 15:47
techno1154's Avatar
techno1154 techno1154 is offline
It is difficult to say with certainty whether or not the brakes are properly assembled and bled properly. Give it the once over to see if there is something that need to redone or adjusted.
You said your XJ was on 35" tires. You did not what gear ratio are in the diffs.
My XJ is fitted with JK take offs wheels and tires which are just over 32", 4.10 ratio, WJ rear disks and WK rotors fitted with OEM calipers and pads on the front. It could lock all 4 wheels on dry pavement. However, in low gear (the front diff have no driveshaft), the rear wheels will spin through the brakes and the front will drag from about 1500 RPM up. Despite the breaks on the rear wheels are good, the engine tend to push through them in low range.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old June 12th, 2017, 16:54
Talyn Talyn is offline
Bed teh pads in properly first.
And a WJ booster & MC does nothing over a 95+ swap. Same Master cylinder bore. I did the swap on my 2000 and experienced no difference.
Yeah, that's what I'm thinking -- going to just bring it into the shop, have them do the once-over.
In the sig -- 4.11's.
Old June 12th, 2017, 16:55
Yeah, that's what I thought too.
Black Magic Brakes: initial impressions anthrax323 Modified Tech Discussion 8 June 17th, 2015 14:06
Black Magic Brake Lifetime? fallacist Modified Tech Discussion 10 April 15th, 2015 18:47
FS: Hella black magic lights ruggedjeep SoCal For Sale 5 January 27th, 2012 19:56
FS: Hella Rallye Black Magic 1000 tcm glx SoCal For Sale 4 January 13th, 2009 23:39
Hella Black Magic 97XJ Modified Tech Discussion 2 December 26th, 2003 07:38
