Old June 8th, 2017, 09:58
MarantzVieta's Avatar
MarantzVieta MarantzVieta is offline
Unhappy OME leaf packs users help please (+2")
Hi everybody,
well I have spent countless hours trying to figure out myself the best 2" lift for my 91 XJ limited and so far I've bought:
+2" Snake coil springs, Bilstein shocks 24-185622 and 24-185639 acording to the 2" lift, and a OMESD40 steering stabilizer.
When looking for the leaf packs, I came across with the CS034RB wich acording to everybody on the internet gave the 2" lift I am looking for, but I called to the store and the guy on the other side of the phone told me I needed the CS034RA for the left spring and the CS034RB for the right even though they have different interior height and the forums claim a 3" of lift for the first one and 2" for the CS034RB.
Is the guy at the store correct or should I follow the internet recomendations and buy both leaf packs the same?
Thanks everybody.
Marantz
Old June 8th, 2017, 10:07
Hypoid's Avatar
Hypoid Hypoid is offline
Re: OME leaf packs users help please (+2")
The manufacturer seems to agree with the internet.
Your part numbers are on the second page of this PDF: http://www.arbusa.com/uploads/PDF/ac...CherokeeXJ.pdf
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old June 8th, 2017, 10:11
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
The guy at the parts store is an idiot.
The 2 have different spring rates and lifts.
I highly suggest you try a different vendor like dpgoffroad or one of our supporting vendors
Old June 8th, 2017, 11:15
hi!
thanks for your fast respones. As I suspected the guy is wrong...
I found this info on the OME page regarding the springs. Look at the side note numer 2, where it says to use A/A Or B/B. What does it mean "Where near level rake is desired"żż
click on the image to make it larger
I'm from spain so buying from the same stores as you guys is impssible and my english also isn't perfect. I should go with the B leafs on boths sides, am I right?
thank you again!!!
Old June 8th, 2017, 11:47
Anak's Avatar
Anak Anak is offline
Stranger
I think you will find that CS034RB is discontinued and you will be ordering CS033RB.
I just installed a pair of CS033RB leaf springs this past February. They are working out to about 2" of lift for me, with no leafs removed. It may be worth noting that my gas tank now holds 26 gallons and I have a cargo box on my roof. My weight may be a bit heavier, but no roll cage.
Whatever you do, spare yourself the pain of dealing with East Coast Jeeps if you are thinking of ordering through Amazon (I have no idea what your options are in Spain--just a word of warning if this is one of them). If there is no shipping advantage to ordering the springs both at once then I highly recommend ordering them one at a time, with several days between the two orders. Standard practice is to simply slap a shipping label on the spring and send it out the door. One by itself is fine, but two of them rattling against each other across several thousand miles means that they damage each other. I had one arrive as a taped up bundle of leafs with no center pin. Both had the plastic guides on the clamps broken up. ARB will try to help, but it is best to avoid the problem in the first place.
Baby it's cold outside.
Old June 8th, 2017, 12:14
md21722 md21722 is online now
I put the CS033RB leafs & 934 coils on my Jeep about 2-1/2 years ago. With one leaf removed it rides about 20.25-20.5" from bottom of fender trim to center of wheel cap. There is no extra weight such as roof racks, heavy bumpers, and stuff like that to weight it down.
I think a lot of the vendors just drop ship from ARB and ARB just tapes a UPS label to the bare spring pack. Mine came undamaged.
Old June 12th, 2017, 05:56
CarbonXJ's Avatar
CarbonXJ CarbonXJ is offline
Same, after 2 years with the overload leaf removed and a 3/4" Rusty's shackle, I'm still sitting at 4" over stock. I only have a Detours Tailbone and 31" spare out back, no extra armor or weight.
My springs also just had a label and shrink wrap, but came undamaged.
Old June 12th, 2017, 12:34
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Installed a set of CS033RB springs on my near stock 1997 XJ. It netted 3-1/2", too much for this rig.
Removing one leaf on each side, as suggested by OME, dropped it an inch to 2-1//2".
The ride height is dependent on how much the rear weighs.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Past BIGoffroad customers with 4", 6", 8" leaf packs..... BIGoffroad Modified Tech Discussion 0 June 10th, 2009 18:10
running 3.5" packs, want a 3/4" add a leaf , 1.5" add a leaf too much, blondejoncherokee Modified Tech Discussion 10 September 25th, 2008 10:40
Stock XJ Leaf Packs with RE 2" add a leaf JasonXJ MWC For Sale/Wanted Forum 0 December 8th, 2007 17:49
complete 3" lift kit with full leaf packs, RE 4.5" coils, (2) 2" coil spacers xDUMPTRUCKx For Sale: Private Party Only. XJ ITEMS ONLY 25 July 5th, 2006 11:33
6" leaf packs 88flexj Wanted: Private Party Only 4 April 30th, 2005 10:59
