Old June 9th, 2017, 11:40
RWKHausSupply's Avatar
RWKHausSupply RWKHausSupply is offline
NAXJA Supporting Vendor
Re: Another one of those Dana 44 leaking axle shaft seal threads
Originally Posted by md21722 View Post
Thanks for the insight. The Yukon kits were purchased in the fall of 2015 at ECGS. I have been slow to get this project done.
Be Leary of ECGS. They box "yukon gears" in white boxes (Not ever what Yukon would do), sell master kits with just about any name on them out of white boxes, and sell shafts under many names out of white boxes. Just some of it... Something PORC was caught doing more times then not a decade agoish, and basically closed the doors for a while...
RWK Haus Supply
All your drivetrain And Jeep needs at a Discount! Call us for all your drivetrain & Jeep accessorry needs. If it is for a Jeep we can get it for less and with superior service. Yukon, USA Standard, Motive, Ten factory, Detroit, ARB, Teraflex, Rock Krawler & A LOT MORE..
All items ship FAST! ~ http://www.rwkhaussupply.com ~ Robert@RWKHausSupply.com Free shipping on Rock Krawler kits. Dana 30 no question asked 1yr warranty axle kits FOR LESS!
Old June 9th, 2017, 14:10
md21722 md21722 is offline
That's pretty interesting to hear. The gears & install kits I've gotten from them have been in factory boxes such as Spicer or USA Standard. These bearings & seals came in a sealed Yukon package. The SYE came in an Advance Adapters box. The only thing that has come loose has been individual bearings like if you wanted a spare set. I figure they buy them in bulk and use them in the shop. I haven't ordered anything from them online though. I just pick up locally when I'm in Raleigh. What's nice is that everything I've asked for they have in stock.
Old June 9th, 2017, 14:24
I should say not all are in white boxes, and or many they stopped that practice when I informed a customer that brought a bunch of items over for install that were in the shipping box still and we opened it up to see this. And I told him to call them on it,. It was a very shifty thing. and then I read a few other occurrences. Given this was years ago. Maybe 3-4.
RWK Haus Supply
Old June 9th, 2017, 15:20
TRAILREADYXJ's Avatar
TRAILREADYXJ TRAILREADYXJ is offline
I'm interested in where you got this info? We do not re box anything unless the original packaging is damaged. For a long time Yukon would package other brands of gears in their boxes, I've even installed OE gears out of Yukon boxes, however they now only sell Yukon gears. This was on Randy's/Yukon, not ECGS. All parts we sell are authentic and from the manufacturer advertised. Now some axle kits may come in plain boxes, but that's because we purchase in bulk so we don't have the retail packaging.
Old June 9th, 2017, 20:23
Looks like worn shaft to me. Garter spring was intact.
Old June 9th, 2017, 20:31
You probably buy shafts by the crate since you sell pre-assembled axle assemblies.
Old June 10th, 2017, 03:07
Exactly! We go through a bunch of shafts.
Old June 10th, 2017, 03:12
It doesn't look like there's grooving or pitting in the pic, just the polished area, can you feel anything with your fingernail? You can probably just clean the seal surface with some 220 grit emery cloth and be fine if no groves or pits.
Did you check the breather?
Old June 10th, 2017, 09:26
Its hard to jam my fingernail in there so I used a small pick. Definitely feel an indent where the seal rides.
Old June 10th, 2017, 22:08
I bought the G2 axles up in Denver since it was faster than shipping. It comes with Timken bearings and CR seals. However, the retainer plates aren't right at least for the early 44's. There is a note on the 4WP website to this effect but I didn't see it until after I realized the holes don't like up . So it's cut the bearing and retainer off and do it again.
Old June 11th, 2017, 17:34
On a side note, has anyone tried using a press and bearing splitter to remove the bearing rather than cutting it off? The collar splits after a 3" cutoff wheel gets about 3/4 of the way through but the bearing is more of a headache...
Old June 12th, 2017, 02:43
You can use a splitter and a press, but I usually just cut them. If you cut the cage off first, then cut the bearing 3/4 of the way (like the retainer), and air hammer with a chisel bit usually knocks the rest off easily, obviously watch hitting the seal surface with the hammer.
If you choose to try to press it, removing the retainer first will help a lot, and I cover/wrap the bearing with a rag so if the cage pops you aren't dealing with shrapnel.
88 steering box input shaft seal leaking ljobbins OEM Tech Discussion 22 January 12th, 2017 13:49
Front axle inner seal leaking philagony94xj Modified Tech Discussion 12 August 5th, 2013 16:25
Dana 35 Axle Seal Leaking Tuckman1941 OEM Tech Discussion 3 July 20th, 2009 10:48
Output Shaft Seal Still Leaking..... BronsonXJ Modified Tech Discussion 2 July 3rd, 2007 11:02
Leaking D44 axle seal Jekyll Modified Tech Discussion 7 May 1st, 2003 19:20
