OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
The dreaded "will these wheels and tires fit'
'98 XJ, 2" cheapie lift. I have come by a set of new JK 5X5 wheels and tires. 17". Aside from the necessary 4.5/5 to 5/5 adaptors, can I mount on my otherwise stock XJ.
I don't know what this means, but I like it: ![]() |
#2
Re: The dreaded "will these wheels and tires fit'
What size tires? And what is the backspace on the rims?
#3
My cousin just got some 265/70/17 tires from 4wheelonline. There is a bit of rubbing on the LCAs at full turn according to him. His rig has 1.25" spacers.
#4
I run the same size tire 265/70/17 but I have a 4 1/2 inch lift . I would run a smaller tire maybe a 245/70/17 and you should not rub to easy .
#5
The WJ Hub bearing is very close to the 00-01 XJ Hub bearing in height. It might work in place of the XJ's. Then possibly Slot or redrill a set of 00-01 XJ rotors. |
#6
I have been using the JK take offs for several years with no problem. I use 2 inch spacers instead the 1.5 inch tat most uses.
Patrick ![]() 1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries. |
#7
I'm dealing with a stubborn P0705 and I'm leaning towards getting a new TCM. This vendor is VIN specific, maybe they could help you with the proper TCM?
https://store.allcomputerresources.c...htcmtcutr.html |
#8
What. The. F*^(!!!!
Kidding Sent from my SM-G975U using Tapatalk |
#10
OP you can run 40s with enough fender trim and bumpstop
Thread Tools | |
Display Modes | |
36" SS Radials, 31" Firestone M/T, stock tires, steel and chrome wheels | Moo Moo Jeep | NAC Classifieds | 11 | February 27th, 2016 15:58 |
32"x10.5"x15 Parnelli Jones Dirt Grip Tires on Black Steel Wheels | Mdub | For Sale: Private Party Only. XJ ITEMS ONLY | 2 | September 1st, 2006 14:26 |
