Old January 24th, 2009, 21:37
ju82takata ju82takata is offline
o2 simulator
Has anyone had any luck with any O2 sensor sim? Also, will deleting the primary cats make improvements in either performance or mpg that would make it worth doing?
Old January 24th, 2009, 21:51
1blackz28 1blackz28 is offline
Re: o2 simulator
I dont have much tuning experience with jeep computer tuning, I do with gm, so here is my best guess at your questions. O2 sims post cat should work as they just feed a generated signal to the computer that a normal operating O2 would. The post cat 02s are generaly only used to check to see if the catylist is working properly and not used for engine fueling. The pre cat O2s are the ones used for fueling. They check how rich or lean the engine is running and along with other sensor imputs decide how much fuel you need. Unless you are specifically tuned to run with out 02s you could damage you motor by replacing these with sims as the computer would not adjust based on 02 reading even if it needed to. Your fuel economy would probably suffer also.
Old January 25th, 2009, 06:48
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Re: o2 simulator
Most on here are not going to recommend removing emissions equipment.
If you are having issues with the downstream O2 tossing out a "PO420"(engine catylist below threshold) I have read on the internet that you can use Spark plug de-foulers on the O2 to eliminate some of the problem.
Google "Fooling the O2 sensor"
o2 sensor simulator???? 2000xj4x4 OEM Tech Discussion 10 November 28th, 2007 17:30
O2 Simulator recommendations OCMI_Teddy Modified Tech Discussion 5 April 4th, 2007 22:48
o2 simulator?? Dirt Modified Tech Discussion 3 November 10th, 2005 11:22
