Old January 2nd, 2013, 07:31
Redsnake Redsnake is offline
Recommendation for Key-On Power wire/location under hood?
I just recently installed the Dirtbound Triple E-Fan kit... and wired the 12V source to the Power Distribution Center 12V Hot location. Since the fans run based on engine/coolant temps, the fans continue to run for a few minutes after shut-down and in doing so I think it's putting a lot of stress on my battery during these COLD nights.
I think during the winter I'd rather just run the power to the temp control via a key-on only power source. Any suggestions or ideas on what to use? It's hard to search for key-on 12V sources so any input would be appreciated. Also, pics are a big help for me if you have any.
Or... some good search terms that I can't think of would also be appreciated.
Thanks
Old January 2nd, 2013, 08:48
ehall's Avatar
ehall ehall is offline
Re: Recommendation for Key-On Power wire/location under hood?
I've had no problems with my electric fan running for a few minutes after power off. But I understand the concern.
There are a couple of switched accessory power wires coming out of the ECM harness, which could be used to drive an intermediary relay (only closed when powered, open when not). Do you have an FSM? If you dont, post your year
my '91 beater rebuild
Old January 2nd, 2013, 08:55
Sorry I forgot to post my year... it's a 2001 XJ, 4.0, Auto 4x4.
I do not have an FSM... so any tips or suggestions would be appreciated. During the summer (when temps get so hot here in Oklahoma... ) I may switch the fans back to a constant 12V to help cool down the under hood temps after running. It seems like the colder weather is harder on batteries than the hotter weather, or at least that's been my experience.
Old January 2nd, 2013, 18:35
the_weirdo's Avatar
the_weirdo the_weirdo is offline
On my 1998, the wire loom that runs from the PCM up the drivers side of the engine bay has a blue wire with white stripe that is key-on power.
I'm not a complete idiot, some parts are missing.
Old January 3rd, 2013, 11:15
scoobyxj's Avatar
scoobyxj scoobyxj is offline
You'll also find this wire in the PDS on the passenger side. If you don't have ABS you could probably snag it from the relay cavity that's supposed to hold the ABS relay.
Dark Blue with a White tracer.
Hood vents best location? Southern96XJ Modified Tech Discussion 22 May 29th, 2015 14:29
Hot ignition wire under hood hookedonxjs Modified Tech Discussion 2 July 11th, 2010 22:32
Hood vent location ? homebrew Modified Tech Discussion 11 November 21st, 2008 08:21
power windows ground wire location? dumbagain OEM Tech Discussion 0 May 16th, 2007 06:40
Hood Vent Recommendation DaffyXJ Modified Tech Discussion 4 June 18th, 2004 14:24
