Old June 5th, 2010, 09:36
xjbubba xjbubba is offline
NAXJA Member # 1524
RuffStuff stiffeners plus 3 or 4-link build
A few pics from my RuffStuff stiffener install. Complete wright up on Pirate4x4: http://www.pirate4x4.com/forum/showthread.php?t=893220
Driver's side UCA mount. OEM bushing drilled to 1/2”
Upper and lower control arms
Driver's side front jacked into place with 3x3 tube. Small bead on front edge of stiffener keeps tube from slipping off.
One done, one to go
Driver's side
Driver's side frame lip cut out to fit modified stiffener
welding complete
Passenger side exhaust clearance (Chevy V8).
~5 inches seperation at the frame mounts and 8inches at the axle.
The Ruffstuff NOT Universal 4 Link Kit! Dan Fredrickson Vendor Advertisements 93 April 12th, 2016 10:45
Upper tri-link build 87xjco Advanced Fabrication and Engineering 31 January 13th, 2009 09:44
to build a weak link in the 44 or not wishihad1 Modified Tech Discussion 1 February 8th, 2008 16:29
The easy way to link up! From Ruffstuff! Dan Fredrickson NAXJA Vendors Info and Feedback Forum 0 August 24th, 2007 09:48
Link to my Taco Build Up caglezxj South East Chapter 2 August 18th, 2007 14:11
