Old October 23rd, 2007, 13:19
BruceB83's Avatar
BruceB83 BruceB83 is offline
Re: XJ Buildup III
I LOVE those Moabs on your Jeep.
Old October 23rd, 2007, 21:24
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Re: XJ Buildup III
Originally Posted by Mosephus
Did you take it to Moab?
Of course, worked very well too.
Speak the Truth-Question with Boldness-Speak without fear.
Old October 23rd, 2007, 21:30
XJEEPER's Avatar
NAXJA Member # 13
Re: XJ Buildup III
LCA Frame mount trimmed, welded and primed. I left the inner brace intact and decided to just clamp the gap tight and weld the seam to retain the strength that it provides, some folks chop these off. You need to trim it tight or the weld will rub on the lower arm during articulation.
Modified trackbar bracket with tabs for mounting brace/under engine crossmember (under construction)
Kind of an odd angle......but I didn't get a good shot of my diff cover armor before I installed it.
Old October 23rd, 2007, 21:45
C85D4x4's Avatar
C85D4x4 C85D4x4 is offline
NAXJA Member #1311
Re: XJ Buildup III
Looking good.......but you need to load up the rest of ur photobucket pics of it all installed
..................unless if thats what ur doing now
Old October 24th, 2007, 20:12
XJEEPER's Avatar
NAXJA Member # 13
Re: XJ Buildup III
Here's the front axle installed. I swapped out the poly bushing on the axle end of the trackbar for a heim, as there seemed to be too much play in it. Solved the problem. Everything works well together.
With 3 days left before Fall Fling, I started my front bumper. I planned on fabbing it to accept a winch that ideally would be recessed below the bumper and recessed into the front crossmember, which I will rework/strengthen. Time didn't allow for this, so I wound up with this.
Main tube is 1.75" DOM, hoop is 1.50" DOM and the side braces are 1" EW. I already had the 1.5 hoop from another bumper project and decided to use it, even though it was smaller than the main. Turned out OK.
Lower braces installed
I was on a dead run on this and didn't get as many shots as I wanted....I finished de-slagging the welds and quickly threw on 2 coats of Krylon on Thursday afternoon. I finished packing the Jeep while the paint dried and bolted in on before we hit the road to Moab so I never even took time to snap any installed shots, so this one will have to do.
Since I didn't get my Viair compressor installed, my ARB's were open for this run. Hells Gate was unusually slippery from a morning storm and sand tracked up from below, so I wound up taking a tug after sliding off the wallI, which allowed me to test the bumper brace as a tow point......yah, I meant to do that
The rig worked well, but as with any newly built rig, needs some fine tuning. I still need to install bump inserts in the coils, add a center strap to tune the droop because with 12.5" travel shocks, there is articulation o' plenty. Gotta get the ARB's plumbed and then work on sliders and rear bumper armor.........you know, a rig is never really "done".
Stay tuned................
Old October 25th, 2007, 01:18
Gojeep's Avatar
Gojeep Gojeep is offline
Re: XJ Buildup III
Still surprised after all that great effort that you did not do OTK on the passenger knuckle to reduce your drag link angle. This would reduce steering strain and effort and also allow you to have raised the trackbar on the axle end to reduce body sway.
Also see you still have to make up your swaybar mounts as well. How are you going to go about that?
Old October 25th, 2007, 01:50
SPORTY XJ's Avatar
SPORTY XJ SPORTY XJ is offline
Re: XJ Buildup III
Looks great nice job
Big Sal
Old October 25th, 2007, 08:24
XJEEPER's Avatar
NAXJA Member # 13
Re: XJ Buildup III
Swaybar endlinks mounts are done, have to up load those shots still. As for the steering, the Currie setup has plenty of clearance on the pass side, but I would like to move it OTK. Problem with this is that Currie didn't engineer an adjustable TRE end on the knuckle end, so flipping their setup is out the question.......unless someone were to rework the end to support an adjustable, replaceable TRE. I might be that someone.........but I haven't ruled out WJ steering either.
Old October 25th, 2007, 16:02
DanMan2k06 DanMan2k06 is offline
Re: XJ Buildup III
Do I spot some harbor freight welding magnets?!
Old October 25th, 2007, 19:42
XJEEPER's Avatar
NAXJA Member # 13
Re: XJ Buildup III
Here you go Marcus........Swaybar link mounts
I'm going to add an antirock swaybar setup soon, so I slapped some cheapo fabbed links together.
Front shock mounts.....with real hardware
Here's a couple of closeups of the front bumper. I'll likely add some tow points and sell this, as I already have another design which accomodates a winch, floating round in my noggin.
Old October 26th, 2007, 01:51
Gojeep's Avatar
Re: XJ Buildup III
They have come up well.
Old November 26th, 2007, 20:42
Gravesdiggerxj's Avatar
Gravesdiggerxj Gravesdiggerxj is offline
Re: XJ Buildup III
any updates?
Old November 26th, 2007, 21:00
XJRunner's Avatar
XJRunner XJRunner is offline
Re: XJ Buildup III
gorgeous
Old November 26th, 2007, 21:38
tjmwr7's Avatar
tjmwr7 tjmwr7 is offline
Re: XJ Buildup III
THis is by far my favorite rig. MAN makes me wish i had your pat.... see i cant even finish writing. I really like how you kept the stock flares.
Old December 4th, 2007, 11:11
mjma's Avatar
mjma mjma is offline
Re: XJ Buildup III
Love the shock mounts!! That's exactly what I need!! Are those stock LCA mounts??? I see you've got the JKS skids welded on and you cut off the stock shock mount and it looks like you may have just gusseted the stock LCA mount to support it and then welded a standard shock mount to the LCA mount, am I following?? Oh, I will be copying that. 12" shocks are a little long up front, and I don't want to rely on my bumpstops to keep me from killing my blisteins!
My buildup ponyracer1 Modified Tech Discussion 21 January 16th, 2007 00:17
XJ Buildup 92REDXJ OEM Tech Discussion 1 April 4th, 2006 19:02
Tow rig buildup crazyoffroader Modified Tech Discussion 11 December 3rd, 2005 18:35
Should I buildup my '91 Limited? xxxjltd OEM Tech Discussion 1 October 18th, 2005 08:54
D70 buildup - a few Qs XJoachim Modified Tech Discussion 1 November 11th, 2003 15:20
