Old November 22nd, 2018, 16:05
gsune1 gsune1 is offline
MEGASQUIRT XJ 2000 STROKER 4.5
Hi guys i have a jeep cherokee 2000 stroker with megasquirt V3 ms2 running. i would like to share experienses , table maps...
thanks
Old November 22nd, 2018, 18:11
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: MEGASQUIRT XJ 2000 STROKER 4.5
Do your gauges work? Any cels?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old November 26th, 2018, 20:04
tbburg's Avatar
tbburg tbburg is offline
Curious about your engine build. Stock bore with a 258 crank/rods and custom pistons?
Old November 27th, 2018, 02:20
RCP Phx RCP Phx is offline
Custom pistons are not required if you run the 258 short rods.
Old November 27th, 2018, 17:15
thanks
I'm not sure how good any U.S. data would do you. Your proximity to the equator, the ocean, and altitude doesn't compare to any conditions we have here.
Old December 5th, 2018, 03:47
yes. i used chevy 250 pistons ( same bore) to increase pin height
Old December 5th, 2018, 03:55
Yes it is correct, but there are 1 mm or 0.04" space between piston and the head. so to increase the piston height ( also increase compession ) you can use chevy 250 pistons. it is not straightforward becase the pin diametter isnīt the same , and we must cut 0.01" from the top of the piston. the gain in power is very noticiable
Old December 5th, 2018, 04:02
I think in car tuning only the atmosphere pression and temp make a difference. in my country we can have fron 0 to 5000 mts height mountains. also i can find temperatures fron 0 to 45š centigrade ALL THE YEAR depends the place.
does the ocean and proximity to equator make any difference?...
Old December 5th, 2018, 05:11
Cummins90 Cummins90 is offline
Your MS is still operating on speed density and will be able to adjust fuel for the decrease or increase in atmospheric pressure. Write symtech labs an email to confirm. Are you using DIY autotune?
Old December 6th, 2018, 03:13
yes
Old December 6th, 2018, 04:26
I would imagine that your fuel formulas are different also.
Old December 11th, 2018, 14:44
Venezuela is ( or was ) your gosoline provider...
Old December 12th, 2018, 06:17
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Venezuela is ( or was ) your gasoline provider...
It is *a* gasoline provider. We get just under 6% of our petroleum from Venezuela, ~20% from latin america in total.
Blown Stroker - Megasquirt - AEM FearNoFish Jeep Street and Performance 57 June 27th, 2017 18:08
2000 XJ with stroker, lift, axles Charlotte, NC kf_chris SEC For Sale / Wanted Forum 21 May 14th, 2012 17:39
2000 Build - 4.6 Stroker, Long Arms, 44/8.8 Combo XJawgi Modified Tech Discussion 50 May 10th, 2009 20:57
Stroker Kit for 2000 XJ? WarnFleXJ Jeep Street and Performance 7 March 13th, 2007 19:56
2000 XJ Stroker, CPS causing Eccessivly High Idle? rbishop Modified Tech Discussion 10 May 10th, 2006 07:59
