Old December 15th, 2017, 19:39
Brian82 Brian82 is offline
0331 head vs 0630.
Rebuilding my 98 4.0. I sent the 0630 head out to get redone and they found 5 cracks... Cracks kills.. I have a usable 0331 head, but I know they are prone to cracking and they have there differences... Exhaust Port size, location, deck thickness, ect.. I still have the older style intake manifold, and the older style exhaust manifold. Am I wasting time trying to use the 0331 head?
Old December 15th, 2017, 19:57
Heavyopp Heavyopp is offline
Re: 0331 head vs 0630.
Yes -- find another 0630 or 7220? Head and have it rebuilt
Old December 16th, 2017, 12:09
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The XJ 0331 head is a waste of time and money. Find an 0630 or 7120 head.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old December 16th, 2017, 12:55
RCP Phx RCP Phx is offline
Or a TUPY version of a 0331 !!!
Old December 16th, 2017, 17:27
Yeah, I don't have a Tupy version or I would have kept it.
Old December 16th, 2017, 17:33
I ordered a 0630 head on rockauto today, screw it. $300 with return shipping for the core. Can't beat that price.
Old December 4th, 2018, 07:16
Wrx19687 Wrx19687 is offline
Hey Brian when you ordered your head off of rock auto. Which one did you order. They have one with temp sending unit hole and one without. I don’t see a temp. Sending unit on mine but with rock auto if you order the wrong one. Just takes up a lot of time to get the correct one. My 0630 head has antifreeze in where the valve is at. I was going to have it check but if it has a crack it would be a waste of money. Any help would be appreciated
Old December 4th, 2018, 08:01
Rockwood Rockwood is offline
After machining, rebuilding, etc, this really isn't a terrible price:
https://www.amazon.com/Edelbrock-501.../dp/B00TSL3P54
Old December 4th, 2018, 15:57
Tim_MN's Avatar
Originally Posted by Wrx19687 View Post
They have one with temp sending unit hole and one without. I don’t see a Temp Sending unit on mine .......
1997-2001 only have one Coolant Temperature Sensor located on the thermostat housing. If you get a head with the temperature sensor threaded hole, simply leave the sensor in place to plug the hole, or use a threaded plug.
2000 XJ with a 0630 Head. How to revert to 0331? savagef82 OEM Tech Discussion 7 January 10th, 2013 06:49
head swap 0630 and 0331 4x4xj07 OEM Tech Discussion 4 July 2nd, 2009 15:44
question switching from 0331 xj head to 0630 tj head jonnyz123 Modified Tech Discussion 2 May 15th, 2009 19:11
0331 to 0630 head conversion question MNJeeper OEM Tech Discussion 1 November 11th, 2008 15:52
