Old November 30th, 2018, 19:07
Arsenalw80 Arsenalw80 is offline
Adding Lift.
Hello, I recently bought a 99 XJ with a 4.5 inch lift. It has an SYE done already and I'm looking to go up to 6.5 inches(Eventually want to go up to 35s + regear.)
Could I do 2" spacers, control arm drop brackets and drop pitman arm, then shackle relocation and or adjustable shackles for the rear? Its a budget build so I don't really want to do anything too crazy if possible. Is a full aftermarket steering needed as well when its mostly a DD?(Snow, Ice and occasional offroading for camping/hunting.)
Thanks!
Old December 2nd, 2018, 19:10
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Re: Adding Lift.
Yes.
I did 2" Teraflex spacers in the front, and a set of rear shackles from a Dodge Ram pick up - older model - early 2000's. It netted me 2 inches all around. I did control arm drop brackets and adjustable front control arms and it helped as well.
Eventually I did do a shackle relocation bracket as well, but not initially. That wasn't for height, but for shackle angle.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Adding more lift I<3Mud Modified Tech Discussion 12 November 25th, 2013 21:24
adding lift webbjeep Modified Tech Discussion 3 January 4th, 2011 10:00
Adding to my lift. CaliXJ Modified Tech Discussion 2 July 29th, 2010 04:39
Adding on the XJ lift KI4KWF Modified Tech Discussion 25 January 6th, 2008 23:07
Adding to a OME lift 540ismiley Modified Tech Discussion 4 March 7th, 2004 13:52
