Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
  #16
Old November 27th, 2022, 22:06
fewloosebolts fewloosebolts is offline
Re: Kronk the Jeep build thread
Originally Posted by XJ-Mayhem View Post
If there’s any smell leftover, try a ozone machine. It’s the only way to actually “get rid” of the smell. Everything else just masks the smell.
Noted, I'll probably do that when the interior is back together
Old November 29th, 2022, 08:26
cj_mike's Avatar
cj_mike cj_mike is offline
Originally Posted by fewloosebolts View Post
Right now, to get it running. Starting off with trying to do a clean, simple, and functional build. Planning on 33's with supporting mods and typical cherokee stuff, frame stiffeners, sliders, the works. Gonna do my best to keep it light. It'll have to be able to tow my teardrop trailer.
Looking forward to seeing the progress and finished product!
Old November 30th, 2022, 12:54
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Just curious, how does an oZone machine fix a small exactly? do you mean like a HEPA filter that generates ozone as well as filtering?
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old November 30th, 2022, 13:45
This is what I was able to find:
"As ozone is created it floats freely in the air and water. By nature it is an unstable molecule and has a half-life of approximately 20 minutes. Shortly after ozone is created it begins to break back down. It will cast off the first ozone atom, which will recombine with either another oxygen atom, reverting back to simple Oxygen (O2), or it will recombine with another gaseous element forming an inert gas losing all of its odor characteristics. Picture a room full of smoke; it is the phenol gas that is released that is the basis of the odor. It is in the air and on the surface of all areas exposed to the smoke. When introduced to that environment, the ozone quickly breaks down as it combines with the phenol gas molecule destroying all odor characteristics."
Old November 30th, 2022, 21:05
Phil's Avatar
Phil Phil is offline
Originally Posted by Phil View Post
I hope this vehicle ends up with lots of levers.
Pull the lever, Kronk
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old November 30th, 2022, 22:34
XJ-Mayhem XJ-Mayhem is offline
Yeah basically the quote you posted is the concept. The ozone attaches to various organic particles and when it does the both kinda react and become something else, essentially destroying what is causing the smell. At least that’s my layman understanding. And no, those HEPA filter ones aren’t strong enough. You need an actual ozone machine, and of course those are not legal at least in California… but Amazon doesn’t seem to care and sold me one.
Because ozone attaches to anything organic… you could imagine the reaction it would have if you took several lung fulls.
For my truck I bought that was previously smoked in, I would turn the timer knob on the ozone machine all the way up, stick it in the truck with the AC on recirculating mode, run an extension cord out the door and close it, then plug the machine in to the extension cord once it was closed in the truck. Once it was done I would open all the doors and let it air out for about 30 minutes. I did that two or three times and it made a huge difference. The smell still slightly comes back if the truck sits in the heat for a long time with the windows closed, but it’s nothing like it was. I probably just need to do it a couple more times.
Don’t let pets around when you’re using it and don’t do it with people in close proximity
Also, since natural rubber is organic it could break down rubber over time. I’d imagine you’d have to do it an insane amount though
Old December 1st, 2022, 19:42
Oh, right. The poison. The poison for Kuzco, the poison chosen especially to kill Kuzco, Kuzco's poison. That poison?
Old December 1st, 2022, 19:44
I'll have to keep your method in mind. Probably could use the machine in my car as well, a couple of big dogs hasn't done wonders for the smell.
Old December 4th, 2022, 10:37
Oldmanxj's Avatar
Oldmanxj Oldmanxj is offline
NAXJA Member #940
This works and is easy to use. https://deadscent.com/.
1989, 4.0, AW4, 231NP
Old December 7th, 2022, 10:44
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter President
Quite the find there my dood. Stoked to see this thing get back on the road.
Old January 28th, 2023, 18:52
Been a while. Got busy with work and then California turned into water world. Started seeing animals going down my street in pairs, but I digress. Finally dropped the t-case and yanked the drivetrain. Other than feeling very old (gonna sore as he'll tomorrow) and giving my garage floor a healthy coating of ATF, things went pretty well. Even started unbolting the trans from the old engine but ran into an issue.
All bolts came out fine except one; one of the revere torx bolt heads on the top of the bell housing stripped. Tried vice grips and it stripped further. Any recommendations on getting this stupid bolt out?
Old January 28th, 2023, 18:53
Also, side note: the oem exhaust manifold on the old engine is not cracked anywhere. I don't think I've ever seen on that wasn't cracked.
Old January 31st, 2023, 20:57
Alboy97XJ's Avatar
Alboy97XJ Alboy97XJ is offline
Sierra Chapter VP
Weld the torx socket onto the bolt?
Old February 1st, 2023, 18:26
Could also death wheel the head off and then extract the remaining bolt after the trans is removed. Then replace them with regular bolts.
Old February 3rd, 2023, 15:08
Haven't had a welder for close to 10 years. Getting a new one is on the to-do list.
Rate This Thread:
2 jeep build thread/blog. zachandandy Sierra Chapter 301 January 24th, 2016 21:40
Minecraft Jeep - Build Thread Alexia Modified Tech Discussion 79 May 12th, 2012 19:25
New Jeep Repair/Build thread DanMan2k06 OEM Tech Discussion 36 August 2nd, 2010 19:31
My New (to me) Jeep build thread maxxpehling NorthWest Chapter 15 March 24th, 2009 22:08
my 89' cheep jeep build thread... KentuckyXJ Modified Tech Discussion 11 February 16th, 2009 19:26
