Stupid question on how to remove top bolt on front diff
jmol50
Colorado
I've got a new 96 XJ and I'm new to DIY repairs and I'm no kid. I've googled all over the place trying to answer this stupid question and I can't find anything. I've replaced all the other fluids in the Jeep (engine, transmission, transfer case, power steering, brakes, and rear differential) all thanks to this forum and youtube) but I can't figure out how to get the top two bolts on the front differential. It's embarrassing. It's in a weird spot and I can't get enough leverage to get them to crack. I bought a socket extension and it didn't work for me - it's at a weird angle. What am I missing? Help me - I don't want to fail at this easy of a task.
Suggestion...
Once the diff cover is removed, drill and tap a hole in the appropriate location for a drain plug. This will make oil changes very easy, which means your more likely do do this needed maintenance. select a location that is low and of enough thickness to support enough threads, ie a thick section. make sure the hole is tapped deep enough so the plug does not protrude out the bottom of diff to protect it from damage. a plug with a magnet in it is ideal as that will help collect metal wear bits, keeping them out of circulation.
Good Luck, keep jeepin!
