Help finding right hole for plug
seanyb505
Simpsonville, SC
I just got my 97 4.0 long block back from the machine shop and I noticed that where the oil pressure sensor fits in there is a plug in the whole. My question is - where is this plug supposed to go? I havent opened up anything since I got it back and I can see one plug in the back and one on the other side of the engine (drivers side). Where should I look first? Thanks
This guy right here. Thats the old oil pressure sensor Im guessing, I need it to go back, and thats not the problem. The problem is finding where the little plug the machine shop put there is really supposed to go. The freeze plug set I got came with a couple threaded plugs, and Im assuming each had its place. Clearly this one is not in its place.
get-attachment.aspx
Damn engine builders, pluggin the wrong hole!
They probably plugged your hole, sorry couldn't help it, to keep debris from the machining process out of the oil galleys. It should just be an extra part. I know mine was when I got my block back.
Did you experience any erratic oil pressure? I seem to remember a while back someone forgot to put a plug somewhere and it ended up messing with their pressure.
