Old February 8th, 2006, 20:29
waggy's Avatar
waggy waggy is offline
cummins 4bt in a xj
has anyone done this yet . i really want to do this and run it on bio
Old February 8th, 2006, 22:48
Oatmeal Oatmeal is offline
Re: cummins 4bt in a xj
Here's a really good write up of a swap into an early Bronco: https://home.comcast.net/~jcmiley/cummins.htm might give you an idea of what kind of hurdles to expect........Hans
Old February 8th, 2006, 22:56
XTrmXJ's Avatar
XTrmXJ XTrmXJ is offline
http://messages.jeep2diesel.org/viewtopic.php?t=177
Old February 9th, 2006, 00:43
scoobyxj's Avatar
scoobyxj scoobyxj is offline
Originally Posted by XTrmXJ
Interesting.
Old February 13th, 2006, 08:13
Lee_N Lee_N is offline
If you're just interested in running biodiesel, how about this for a diesel swap - use a Mitsubishi 4D55 (2.3L) turbodiesel found in some Mitsubishi Mighty Max pick-ups, Dodge D-50 pick-ups, and Ford Ranger pick-ups. This engine will bolt to an Aisin Warner KM148 4 speed auto, which in turn will bolt to an NP231 tcase. You need an NP231 with the 23 spline short or medium input shaft. These have been bolted together but no one has figured out all the details from there (oil seals, etc).
The Mistu engine is harder to find than a 4BT, but it's much lighter and more compact. Should be a lot easier to fit in the engine bay, plus no adapters are required. This is the combination I would like to try.
Old February 13th, 2006, 18:06
dan89XJ's Avatar
dan89XJ dan89XJ is offline
What is a Aisin Warner KM148 4 speed auto ? that the trans in our XJ's ?
Old February 13th, 2006, 20:53
The KM148 is the auto found in a first generation (thru 1990) Mitsubishi Montero. It is a hydraulically controlled transmission and can be found with a hydraulic torque converter lock-up. To mate to the 4D55 turbodiesel you need to find one behind the 2.6 L four.
Old February 14th, 2006, 05:58
tealcherokee's Avatar
tealcherokee tealcherokee is offline
A W 4
Old February 14th, 2006, 06:12
A W 4
If you mean the KM148 is the same as the AW4, no it's not, but it's just as bulletproof. The AW4 is the same as what's installed in later Montero's but the KM148 is completely hydraulic. Just the overdrive is controlled by a solenoid.
Old February 14th, 2006, 06:16
oh, nice, a working AW4
my solenoids are going after 190k miles :\
Old February 14th, 2006, 06:49
Root Moose's Avatar
Root Moose Root Moose is offline
Interesting.
Mechanically is the AW4 the "same" as a KM148 the way a 700R4 is the "same" as a 4L60E?
More importantly I suppose, does the KM148 have a removable bellhousing like the AW4?
Old February 14th, 2006, 09:22
Yes, the bellhousing bolts on. This transmission has been used in Toyotas and Isuzus. It's also known as an A44DL or an AW372L (the L indicates the lock-up feature). As a result, you can use an Isuzu bellhousing and bolt on to a Chevy V6 bolt pattern (the 2.8, 3.2, etc)or an Isuzu V6, a Toyota bellhousing to bolt on to a Toyota V6 or V8, or the Mitsubishi bellhousing to bolt on to the 2.6L 4 or 3.0 & 3.5 V6.
I don't have any info on whether the internals are similar to the AW4.
Old February 14th, 2006, 14:26
vetteboy's Avatar
vetteboy vetteboy is offline
I once came across a guy with a Suzuki who had swapped in a small diesel motor from a Chevy Chevette. He used the stock Chevette transmission and clutch, ran a short intermediate shaft to a divorced t-case with 6:1 low gears, and 5.38s in the axles. Still gutless, but it worked and was a pretty cool thing to see.
Old February 15th, 2006, 12:32
xjfrank xjfrank is offline
I abandoned a 4bt swap, the cost will eat you alive. I was going to use the nv4500 trans, you can get them freshly-rebuilt and shipped to your door just under 1000 dollars from GCParts (very large rebuilder, I can get contact info to you if you need it, it was 963 dollars on a pallet from the midwest to me in Virginia, might cost you slightly less if you're closer to them). What'll kick your teeth in are the rest of the things, clutch for example. Go price a good HD clutch for a cummins (4bt/6bt nearly the same with varying number of cyinders, clutch is the same, so you can look at the dodge sections). Every part is expensive, so try to get the 4bt with the bellhousing, flywheel, etc get every darn extra thing you can.
A jeep with a 4bt is at burnsvilleoffroad.com if you don't see his pics (it was his jeep that he did this to) then email him.
Old February 15th, 2006, 13:13
87manche's Avatar
87manche 87manche is offline
that's the place that did that KJ CRD motor swap into a TJ isn't it? Now that would be a project..
test What is the best XJ? F. F. TEST Forum 40 April 21st, 2007 02:10
AZ: Final remaining parts from XJ project ... good stuff Blatant For Sale: Private Party Only. XJ ITEMS ONLY 11 October 4th, 2004 09:09
95' stock xj in NorCal for sale--make offer Big Red For Sale: Private Party Only. XJ ITEMS ONLY 2 December 18th, 2003 16:57
WTB front dana 30 diff guard for 90 xj in CA lapaul Wanted: Private Party Only 2 December 11th, 2003 13:27
95' stock xj in NorCal for sale--make offer Big Red Sierra Chapter 0 December 7th, 2003 12:29
