MONSTERxbla
- Fresno
I have searched....replaced tb with a bbk 62mm, after install noticed that the idle was a little more erratic than I remembered (about 750 rpm) but seems to vary +- 30 rpm (I have a scangauge 2). after a short test run I notice that upon putting jeep in park the rpm's were about 1100rpm, I blipped the throttle thinking maybe linkage was binding, no effect. if I turn the jeep off, then restarted, the rpm's go back to about 750rpm. I checked for any obivious air leaks, found none. I pulled the iac and cleaned it. I noticed a little bit of play on the plunger, I am thinking this may be the problem. the issue is very consistent, only happens after putting jeep in gear. thanks in advance.
