Hybrid toy/ D44/ 5x4.5 lug/ big brake/ bolt in axle...
rredalty
Lenoir City, TN
Ruffstuff specialties toy 8" housing, stock toy 4.88 third, lockrite, superior waggy d44 inner shafts, dodge D44 outer components including knuckles, brakes, 1.5" 35 spline stub shafts... used to retain the 4.5" 5 lug pattern. Axle has more clearance than a D30. Knuckles are drilled and tapped for high steer. Running a Rugged Ridge steering set with HD tierod and draglink. 61.25" WMS. Adams driveshaft built the shaft and is setup to be used behind an AW4 Jeep. All brackets used are Rubicon Express and also has JKS mini skids. I'll take $1650 for all listed here, Less than half of what's invested into a truely one of a kind axle still using off the shelf parts.
That's a tough axle!!
So... where are the adds for the stroker, wheels, tires, etc?
Are your wheels 17s?
rest on pirate and tor. wheels are 15".
