Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period. |
Thread Tools | Rate Thread | Display Modes |
Hey techies, it's me again!
I'm thinking of doing a dual-boot config on my new laptop (WinXP) with Linux. My questions are: Which Linux distro to use (preferably free, mostly just to learn with and tinker), and where to find a good guide to partitioning and configuring the dual-boot. Any URLs would be most helpful. Thanks again! jml1911a1 |
#2
Re: Linux for an amateur
I'm running a Dell L400 laptop with SuSE 9.1 and Win2k. It's been set up as a digital darkroom.
I have a small (128mb) boot partition, a W2k partition, a Linux root, Linux swap, and a shared partition (currently FAT32.) I'm using the grub boot manager as well. The secret path seems to be to start installing Linux, and just create the first boot partition. Start over with the Windows install, creating a second partition and installing Windows there. Once Windows is happy and completely updated, go back and start installing Linux again, creating it's own root and swap partitions. SuSE 9.1's installer detected the Windows partition, and configured grub properly. SuSE is not free. But I'm certainly happy with it. You can download a floppy based installer that will pull the distribution down through a network connection (assuming you have a high speed connection.)
ChiXJeff Lifetime member "Jeeps are Cherokees. All other models are wannabes." Deb. K. |
#3
Linux mandrake, easier with two hard drives, install windows and then install mandrake linux. WHen it boots it will come up with a nicely colored screen with the choice to boot linux or windows. Mandrake 10 is free, just grab the ISO images from a mandrake mirror, burn them to a cd and thats it. Easiest I have seen yet, runs well and has open office with it. It is also the easiest to install I have seen yet...
#4
I like Red Hat. Mandrake is very similar though, and has an easy installer.
I use Red Hat Enterprise (these forums use Red Hat Enterprise 3.0), and that is not free. However, there is Red Hat Fedora. Usualy, install windows, then go through the Red Hat or Mandrak installer. It will walk you through setting up a dual boot system. Usually no problems...... but have a back-up just in case. ![]() Glenn
![]() 2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project! |
Thread Tools | |
Display Modes | Rate This Thread |
Auxiliary Fan + Cooling Temp Sensors | bchulett | OEM Tech Discussion | 11 | March 10th, 2007 12:22 |
Please help me with this aux fan switch before I light my POS Jeep on fire. Pics! | 90Pioneer | Modified Tech Discussion | 12 | May 15th, 2004 20:53 |
Does running both a pusher and puller elec fan actually work? | Scriff | Modified Tech Discussion | 11 | March 9th, 2004 06:32 |
Dual 12" puller and single 10" pusher fan install. (pics) | Bender | Modified Tech Discussion | 11 | September 19th, 2003 17:06 |
90XJ, 4.0: engine fan blows into radiator | burntkat | OEM Tech Discussion | 8 | June 20th, 2003 10:46 |
