deloxx
- Massachusetts
All,
I am in the process of building an 89 Comanche with a full 1998 cherokee swap. Everything from the comanche is gone, so the vehicle is effectively a 98 cherokee for diagnostics. Everything has been swapped over at this point.
I am unsure of where to start my diagnostics and I need some guidance. I am getting no spark and I am receiving several DTC's. Namely P1694 and occasionally P1698 and P0700.
I am worried there is a wiring issue or one of the PCM/TCM modules has failed. The entire wiring harness was removed and installed into the comanche, which is a lot of movement for 25 year old wiring and components..
All the underhood grounds were thoroughly cleaned and in reinstalled today as well. I have the factory FSM, but it doesnt seem to give much guidance for troubleshooting this issue.
