Bradlybob
- Lancaster, CA
I removed my front d-shaft on my 91 xj trying to isolate my driveline vibrations. To my surprise it was the front shaft that was vibrating. The double cardan joint is jerky. The u-joints seem fine but the little assy in the center of the joint is stiff. How do you grease it? Do i have remove the 1st u-joint?
Thanks, Brad tel
Thanks, Brad tel
