Old December 25th, 2006, 12:32
saweddoffjeep saweddoffjeep is offline
weird noise from engine
so last night i was driving home and i started to hear a strange sound coming from the passenger side of the engine, it sounds like scratching, or when a cd skips, and i have no idea wat that is
any suggestions?
Old December 25th, 2006, 12:55
Midnight Krawler Midnight Krawler is offline
Re: weird noise from engine
Check your distributor cap and rotor to see if they're rubbing. The bearing in the distributor can make a squeal or chirping noise.
Old December 25th, 2006, 14:13
i checked my distributor cap and rotor, and all that seems fine, but when i popped the hood i noticed my radiator overflow tank was empty, and there was the green liquid all over the engine compartment
would that be what was wrong?
Old December 25th, 2006, 16:08
filled the coolant bottle up, and i tried to start it up, but it sounds like grinding now, could that be the starter? im guessing it is
Old December 25th, 2006, 18:17
sw4218's Avatar
sw4218 sw4218 is offline
Most likely it's the alternator bearing. Take the serpentine belt off and spin the alternator and see if you hear that noise. That nasty green stuff can do a number on alternators.
Old December 26th, 2006, 00:26
i dont think it could be the alternator, but i would definately take a good look to see just incase, i also checked the starter and there was a fair amount of oil and the nasty green crap all over it
Weird Engine Noise XJiggy OEM Tech Discussion 10 December 9th, 2006 23:05
A Weird Noise – Never heard one like it (but I could use some help) liviu OEM Tech Discussion 3 May 24th, 2006 07:44
Weird noise falcon556 OEM Tech Discussion 7 April 8th, 2006 18:06
Weird Front Noise jeepsrock Modified Tech Discussion 1 December 26th, 2005 13:25
Help..weird noise at 55-65 mph!! sticksb OEM Tech Discussion 1 August 7th, 2003 23:39
