Old July 19th, 2003, 11:42
mcconnaughey's Avatar
mcconnaughey mcconnaughey is offline
Rear axle bearing replacement
I have a 8.25 axle in need of wheel bearing replacement and have never this before. I want to know the process being that the Haynes manual isn't to precise. My understanding is the bearings are retained in the axle end, that I will need to remove the dust seal and then..... what? Any special tools I would need, thing to look out for, and so on would be of great help.
Thanks,
McConnaughey
Old July 21st, 2003, 15:56
btt
Old July 21st, 2003, 19:40
MJR's Avatar
MJR MJR is offline
Yes the C-clip 8.25 axle has the bearings in the housing ends. Problem is if the bearings are bad so most likely are the shafts since the roller bearing ride directly on the shafts. It is common for them to get pitted and need replacement. You do need a bearing puller and installer tool.
Rear axle seal? XJHOX Modified Tech Discussion 8 June 23rd, 2005 14:30
Need to know quickly, Axle ??? Big Hank Modified Tech Discussion 4 December 7th, 2003 22:02
REar CV driveshaft BigBlk XJ Wanted: Private Party Only 3 October 26th, 2003 10:25
rod and main bearing replacement? Erik the Red OEM Tech Discussion 6 May 22nd, 2003 09:47
