Old November 8th, 2004, 17:29
jccj7 jccj7 is offline
Post Hot (to the touch) Hubs
I was washing the XJ today and noticed some steam/vapors coming from the hubs when water spashed on them. I just finished a 15 mile drive home before washing. I put my hand on the hubs and they were almost hot to the touch.
I have the Warn hub conversion and both sides were in the "Free" position. I also serviced the hubs about a month ago (cleaned and repacked with hi-temp bearing grease). I believe I reassembled the hubs correctly and verified that lock locked and free unlocked the hub.
So any ideas? Normal? I know hot hubs in the US Army means something is wrong with the wheel/hub/axle.
TIA,
JC
Old November 8th, 2004, 19:25
kmagnuss_2000 kmagnuss_2000 is offline
Re: Hot (to the touch) Hubs
is it just the hubs or the whole wheels? Mine did that when the brake froze up.
Old November 8th, 2004, 19:34
xjaddiction xjaddiction is offline
NAXJA Member #666
Make sure they have plenty of grease, but i think what your feeling is normal. Mine get hot to the touch too( I have the hub conversion as well), but I think this is just heat from the brakes.
Greddy
Old November 8th, 2004, 19:55
Sero's Avatar
Sero Sero is offline
Your brake rotors are bolted right on to the hubs, so the hubs will get hot. Just compare the left to the right side and if their the same I bet everything is OK.
Old November 9th, 2004, 17:28
Ok, good deal.....thanks for the second opinions.
jc
exhaust is too hot, not engine masterdon OEM Tech Discussion 13 August 17th, 2006 18:06
BEARING HUBS!!!! What's the deal?!? CheapXJ Modified Tech Discussion 32 March 18th, 2005 17:25
D44 bearing install problems....HOT STUFF! Ed in North Ga. OEM Tech Discussion 7 November 6th, 2004 08:33
Hubs......changing from disco to non lndrvrxj OEM Tech Discussion 6 January 14th, 2004 23:26
Blown hubs bluexj89 Modified Tech Discussion 7 November 16th, 2003 21:27
