Old March 31st, 2004, 18:32
88woody's Avatar
88woody 88woody is offline
Weird noise...it's driving me nuts!
For the past few days, every time I would hit the brake, or put my XJ in reverse, I would hear an audible click, click, click from under my dash. (It almost sounds like when the rear defroster turns off). It's doing it almost constantly and i can't locate the source. Any ideas?
It also happens when I have my blinker on, when my windshield wipers are on delay, or for no good reason at all...
Also, my blinkers are REALLY slow. ive changed the flasher, and it works fine for a day or so, but it goes right back.
In an unrelated question, I notice that under neath my dash, there is a yellow box that has wires going into it, and the words "AMC" on it. What is it?
There is also a clear box, about 2" long, 1" wide that has a bunch of plastic gears in it. It says something to the effect of "smog-check" or something like that. Any ideas?
Old March 31st, 2004, 19:21
RTicUL8's Avatar
RTicUL8 RTicUL8 is offline
Re: Weird noise...it's driving me nuts!
I'll take a stab at the last two questions.
The yellow box is the cruise control module.
The clear plastic box is the emissions maintenance timer - you can yank that one with no ill effect.
Old March 31st, 2004, 20:05
8Mud's Avatar
8Mud 8Mud is offline
My rear wiper stuck in the middle, caused a clicking in the fuse box, guess it was a circuit breaker. The rear motor tries to zero itself or park itself and will overheat when it canīt.
Old April 1st, 2004, 19:00
88woody's Avatar
Well,
All my electrics work fine, it's just really annoying
Old April 2nd, 2004, 03:47
Ed in North Ga.'s Avatar
Ed in North Ga. Ed in North Ga. is offline
try testing it with the fan off- I had a chunk of tape that sat near my fan-every time I`d hit a bump its get close enough to pop it an make evil clicky noises-- if its a constant click, feel the relay in the fuse box- a relay going bad will do this when electrical load is put on it(tail lights on/blinkers)
When(if) you pull the maintenance timer, remember- the bulb in the dash that lights MANT. fits every other socket on the board. If you burn one, remember its there for replacement.
Old April 2nd, 2004, 07:49
wek91xj's Avatar
wek91xj wek91xj is offline
yea, iv got a constant clicking whenever i hit the brakes, i think its from when i turned real sharp goin like 20 in a mud puddle and bent somthin on the brakes, its been like this for 5 months, i just ignore it now cause the brakes work fine
Weird popping sounds up front Fonzie14 Modified Tech Discussion 3 December 9th, 2003 13:43
Loud Noise in 4x4-Front Maybe? juicexj24 OEM Tech Discussion 2 December 7th, 2003 06:39
Brake Noise Urban Redneck Modified Tech Discussion 4 December 6th, 2003 20:18
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 14:51
Help..weird noise at 55-65 mph!! sticksb OEM Tech Discussion 1 August 7th, 2003 23:39
