Old November 22nd, 2006, 18:24
DansGreyMj's Avatar
DansGreyMj DansGreyMj is offline
window seals
is there a way to replace the rubber along the bottomf of the roll down windows if posible how do i do it and where can i get new ones, and its an 87 mj
Old November 22nd, 2006, 19:28
Zoro Zoro is offline
Re: window seals
Yep, really easy to do. You can grab the fronts from a 4 door XJ. I've got some if ya want.
Old November 22nd, 2006, 19:59
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Re: window seals
my drivers side lower gasket on the outside sometimes folds in and gets stuck in the summer and I have to push the window down to get it to go down (auto windows)
Not sure how that happens, no other window does it.....hehe.
Old November 22nd, 2006, 20:48
DansGreyMj's Avatar
Re: window seals
mine are manual and the driver side does it also
Old November 22nd, 2006, 20:49
DansGreyMj's Avatar
Re: window seals
what would they be called if i went out to buy new ones at a parts store
Old November 23rd, 2006, 05:05
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: window seals
try here www.teamcherokee.com/Weatherstrip
weatherstrip,
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Air blowing in abve window channel felt seals Ray H OEM Tech Discussion 6 April 6th, 2010 13:42
D30 Seals - Aftermarket Outer Axle Seals RAVC1 OEM Tech Discussion 7 September 2nd, 2006 07:38
looking for rear window window trim for 96 cherokee diablo007 Wanted: Private Party Only 4 May 24th, 2006 18:10
Window seals BSH OEM Tech Discussion 1 November 30th, 2005 19:17
window rail seals? willys8 OEM Tech Discussion 3 June 1st, 2003 22:02
