Old May 4th, 2010, 17:38
NeXJ NeXJ is offline
Broken Hood Latch - How to fix or get hood open??
I was just about to start some attempts at getting a dead cylinder fixed on my 92 XJ and for the first time ever I couldn't get my hood latch open (!!). Thing's been sitting too long maybe? But anyway- the release pulled out (more easily than usual) with no 'kunk' sound and the hood stayed shut. I'm really not sure what's up - but attempts to pry the thing open with a cloth covered screwdriver while holding the hood release 'out' completely failed. Not sure what went wrong - but has anybody here dealt with this before?? I tried searches for hood latch and hood and latch and came up with nothing...
Old May 4th, 2010, 17:57
joe_peters joe_peters is offline
Re: Broken Hood Latch - How to fix or get hood open??
You will probably have to remove the grill to get to the hardware.
Old May 4th, 2010, 18:08
SINCITY192 SINCITY192 is offline
make sure the hood release cable is still together by hood release puller or button which ever u have cuz mines did the same exact thing and when i look the pull for the hood release cables were broken so i had to take vise grips to the cable to pop the hood
Old May 4th, 2010, 18:17
orange orange is offline
Scroll down to bottom of this page for similar threads.
Old May 4th, 2010, 18:21
what threads...? or did you forget to post something?
Well - the handle came off a long time ago - so I've been using pliers for a few years. the thing still retracts - so I'm ASSUMING the cable's fine - but somehow the actual latch or mechanism with spring At the latch is cooked (?). Sounds to me like taking the grille off is going to be the way to go... (ack). There's a torx screw visible at the seam between the hood and fascia - but I don't have a long torx driver that's so thin it would fit through. I suspect that would be kind of hard to come by...
Old May 4th, 2010, 18:27
MT Mike's Avatar
MT Mike MT Mike is offline
Scroll ALL the way down to the bottom of the page. See the box with the title that says "Similar threads"? Choose one, click on the title and read. If it doesn't answer your question, hit the back button and pick a different one.
Another good source is here.
Old May 4th, 2010, 18:54
AH!!! Guess i didn't go far enough. How come I used the SEARCH function and came up with NOTHING... just random stuff about ANYTHING - but that one seems VERY on-topic..(?) Thanks!! Mush apreshiated... (actually being silly not drunk...)
Old May 4th, 2010, 18:59
MT Mike's Avatar
The google search part of the link above works much better than the vBulletin search that the forum uses. Read up on the google search part and try it. You'll never click on the search button again....
Old May 4th, 2010, 19:01
yeah- I already gave up with THAT search... maybe it's searching by first letter...? perhaps number of letters...? ha. Anyway- I found THIS thread:
http://www.naxja.org/forum/showthrea...ght=hood+latch
and I'm pretty intrigued by the hood pin thing - though it's a bummer all the pics are missing...!
Old May 4th, 2010, 19:02
Seems the best solution is mentioned at the end of that thread. NO DISASSEMBLY required. Hit the connecting rod with vice grips and yank em over... done... going out to try right now!
Old May 4th, 2010, 19:13
xcm xcm is offline
once you're done, replace it with hood pins, so it doesnt happen again! it will happen at the worst times
Old May 4th, 2010, 19:30
OR put in a new cable, keep the whole thing lubed, and it won't happen again.
Old May 4th, 2010, 21:21
... or that too... though I'm not even sure the cable's broken... but I don't suppose I'll know until I get the thing open!
Old May 5th, 2010, 09:20
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
This is a sticky over on CC. I think it'll cover your problem...and then some. MJ's and XJ's are the same in this instance.
http://www.comancheclub.com/forums/v...57 6c5505c15e
Old May 5th, 2010, 10:04
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Was just going to link that, Paradise. Haven't tried it yet because luckily I haven't had the need to yet.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Open hood....without cabin latch? 01din OEM Tech Discussion 3 July 6th, 2008 20:29
Need help with hood latch......Cant open it keithscianna OEM Tech Discussion 5 November 6th, 2007 05:04
Hood Latch Help PLEASE BlueberryXJGirl OEM Tech Discussion 21 October 16th, 2007 09:17
Door won't open... could be broken handle/latch... need help Redsnake OEM Tech Discussion 11 December 6th, 2006 13:24
hood release broke,cant get hood open?? hammerheadxj OEM Tech Discussion 7 January 30th, 2006 14:06
